04-24-2013 07:51 AM - edited 03-07-2019 01:00 PM
hello,
I want to limit the bandwidth of my Catalyst 3750 series switch, I read the cisco documentation and I applied the commands but I didn't get the wanted results.
for the outbount trafic it's ok, but for the inbound traffic I used policing but I get an unstable traffic.
I used, an access list and a class-map to classify the traffic and then a policy-map.(I followed the steps mentioned in this site: http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a0080883f9e.shtml#concept11 )
someone has a solution?
sorry for my bad english and thanks for help.
04-24-2013 09:28 AM
you need to configure an aggregate-policer
04-24-2013 11:57 PM
according to the site you gave me, the agregate policer is used when we have more than one class, in my case I have only one class-map.
I want to know if there is someone who configured a 3750 cisco switch and to reduce the bandwidth, it seems that it's impossible to have a stable traffic.
thanks.
04-25-2013 10:46 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Please clarify "stable" vs. "unstable" traffic. Or, what's the issue you believe the policer is creating?
04-26-2013 05:27 AM
I have this configured on a 3750 to limit traffic to a particular server
class-map match-all SEP
match access-group name SEP
policy-map Police
class SEP
police aggregate SEP
mls qos aggregate-policer SEP 1024000 192000 exceed-action drop
mls qos
ip access-list extended SEP
permit ip host 10.2.1.201 any
permit ip any host 10.2.1.201
permit ip host 10.2.1.48 any
permit ip any host 10.2.1.48
Int range fa1/0/1 - 48
service-policy input Police
int range giga 1/0/1 - 4
This works perfect to limit traffic to and from the 2 servers (10.2.1.201 and 10.2.1.48)
07-09-2013 03:02 AM
hello,
thanks for your answers, still now I don't have perfect results, what I mean by stability is that when I apply a policy and every time I do a test Imust have the same result ie the same rate, expect this is not the case(when I tested the rate I didn't have the same results).
thank you any way.
