LIMITING CISCO POE SWITCH OUTPUT VOLTAGE PER PORT - C9200L
We have situation in C9200L, Our Cambium AP not working in PoE port but working with power injector. Cambium TAC highlighting that the device will support only if the input voltage is <=30, Whereas the CISCO switch ports output voltage is 48 to 52 Volts. Can you suggest how to restrict per port to release only 30Volts.
Leo Laohoo
power inline max 30000
