Limiting outgoing traffic on a single l2 port on nexus 7000 1GB port
Lim Victor
I am trying to limit the incoming and outgoing traffic on a l2 port to 8mbps for a ip subnet within the nexus 7000. The port is connected to my ISP router which has a bandwidth of 20mbps.
I read thru a few articles and it seems there is no way to do that. Policing won't work on a l2 Port and shaping cannot be applied on a port level. Am I right?
https://supportforums.cisco.com/thread/2045274
Any approach how I can do it? In
I have been reading thru the qos guide for nexus release v6 and have problems understanding the different queues.
Thanks.
Leo Laohoo
Who provides the router?
Marwan ALshawi
Lim Victor
Hi Guys,
Thanks for the reply.
My Nexus 7K is doing BGP peering with the ISP router.
I did the following
ip access-list Test_ACL
permit ip 10.0.0.1/27 any
policy_map Test_8mbps
class Test_ACL
police cir 8000000 pir 8000000 violate drop
int eth 4/2
service-policy output Test_8mbps
and i got the following error
N7K(config-if)# service-policy output Test_8mbps
ERROR:  Unable to perform the action due to incompatiblity:  Module 1, 2, 4  returned status "Egress policy on an L2 interface is not supported"
I tried using queuing
Policy-map type queuing Test-2Mbps-in
class type queuing 2q4t-in-q-default
bandwidth 2 mpbs
int eth 4/2
service-policy type queuing input Test-2Mbps-in
Doesn't seem to work.
It is still showing more than 2mbps when i do a show interface int eht 4/2. Should i be using "show policy-map interface ethernet 4/2" to confirm?
