04-24-2006 07:50 AM - edited 03-05-2019 11:51 AM
I've configured a reverse telnet, how can i remove speed in the aux configuration? when i use no speed, i've got the message "failed to change".
04-24-2006 08:25 AM
I've changed it into 9600.I can't get the prompt
Here's what's written on the screen :
Router#telnet 10.1.1.1 2005
Trying 10.1.1.1, 2005 ... Open
User Access Verification
Password:
Password OK
*Mar 4 05:07:02.644: %SEC-6-IPACCESSLOGP: list 123 permitted tcp 10.1.1.1(0) -> 10.1.1.1(0), 64 packets
*Mar 4 05:12:02.644: %SEC-6-IPACCESSLOGP: list 123 permitted tcp 10.1.1.1(0) -> 10.1.1.1(0), 2 packets
*Mar 4 05:19:02.644: %SEC-6-IPACCESSLOGP: list 123 permitted tcp 10.1.1.1(0) -> 10.1.1.1(0), 4 packets
can anyone tell What's the source of the problem
04-24-2006 08:54 AM
It would be helpful if your would post the relevant parts of the config. It looks like the reverse telnet works - at least you appear to connect and to be prompted for a password. After that it appears that access list 123 is seeing your traffic (the source and destination addresses are the address that you use for reverse telnet). If we could see the config then we could see what access list 123 is being used for.
Rick
