link aggregation is not working properly on catalyst 9300 switch.
Namgyal
i designed a network with link aggregation as shown, but there is link agregation problem i.e. link is getting down while removing one of the port on link aggregation.
スクリーンショット 2024-08-28 114013.pngwaiting for support
6 Replies 6
Mark Elsen
  - It depends on  what does link removal implies and how it is done ; always check logs on the switch where the link is removed and the remote partner ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I will check the detail log, but while i removed the one of the lan cable connected with port-channel on L2 9300 switch to active L3 9600 switch, then the connection is down for 5~6 seconds, and there is no down time while I removed the lan cable connected to standby L3 9600 switch.
and similarly if removed the lan cable with port-channel connected from L2 9300 switch to server then again there are no down time.
Hello @Namgyal ,
How are you doing your tests ? are you pinging  a server that is downstream the L2 switch or are you pinging the L2 switch management IP address ?
the 0 downtime on standby L3 switch can be expected if actually the packets are not going through it.
However, 5-6 seconds downtime is strange.
So it is better that you provide more details on your tests and your test traffic.
Hope to help
Giuseppe
Hello
Can you elaborate on this please?
Kind Regards
Paul
@paul driver
use
no lacp suspend-individual <<- if one link is remain in PO the PO is suspend this command will disable default behave
to be sure this is case here
share
show lacp internal<<- in both L3 SW
show port-channel summary <<- both side SW
show ehterchannel summary <<- both side SW
MHM
