Link Aggregation with QSFP links on 5672UP
Turbo727
Hi Everyone,
I have a question on my mind for quite some time regarding QSFP aggregation on Nexus 5672UP switch hoping gurus here could shield some light.
According to the data sheet, 5672UP supports 6 true QSFP. I am in a situation where a server require 2xQSFP(40Gbps) links to be bundled together. I wonder with QSFP, can I treat it as normal SFP+ interfaces and aggregate two QSFP links together using vPC to get 80Gbps? If it is possible, it absolutely offers better bandwidth and redundancy.
Reza Sharifi
Yes, you can aggregate the 2 QSFPs together in a Portchannel. Just remember if the server has 10Gig SFP+ interfaces, you need a special cable with one side with multiple SFP+ interfaces (4) and the other side 40Gig with MTP interface.
If the server has 40Gig interface than you can go straight from the switch to the server.
jkilleda
Level 3
Level 3
Hello Ben,
QSFP+ evolved as the standard to support 10Gb/s data rates per SFF-8436 whereas SFP+ is an enhanced version of the SFP that supports data rates up to 10 Gbit/s.
http://www.fiber-optic-transceiver-module.com/what-are-the-differences-between-sfp-sfp-xfp-qsfpqsfp-cfp-and-qsfp28.html
 You can connect two QSFP links together using VPC
https://www.juniper.net/documentation/en_US/junos/topics/concept/virtual-chassis-qfx-series-understanding.html
