broadcast storm control using QOS to stop it to punt the CPU
deepak george
How do i supress the broadcast in Nexus switches(5672UP's)
Our's is a lab environment and we have a lot of teams generating a lot of broadcast traffic. Broadcast storm control detection will help, however  the traffic hits the CPU and would cause CPU utilisation.
Can i use QOS to ensure that the traffic doesn't punt the CPU?If yes can you share any info
7 Replies 7
Reza Sharifi
On the 5600 series, you can configure broadcaset control on Portchannels as well as host ports (FEX ports).
Here is the config guide:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5600/sw/layer2/7x/b_5600_Layer2_Config_7x/b_6k_Layer2_Config_7x_chapter_01101.html#task_1072339
Thanks Reza,
I am looking for an option to control the broadcast storms punting the CPU like COPP or QOS.
Do you have any suggestions for the same.
Deepak
So, what is the cpu utilization when there is a lot of broadcast traffic? Does it go up significantly?
I think if you stop it at the ingress ports (access ports) than you should not see much of cpu utilization by broadcast traffic.
Hi Reza,
Thanks for getting back.
I am looking to configure broadcast storm control on a layer 3 interface on N5672UP.
I know that broadcast storm is a layer 2 feature and might not support on Nexus. Is there a way i can overcome this as this is available on a normal catalyst switch.
Ours is a development enviornment and we have a lot of traffic generated. This is our aggregation layer switch and we have a lot of gateways confgured
The CPU utilisation would be between 85 to 95%
Hello
@deepak george wrote:
Hi Reza,
Ours is a development environment and we have a lot of traffic generated. This is our aggregation layer switch and we have a lot of gateways confgured
Broadcast isnt traversed over L3  so as resa suggested negate as close to the source as possible (storm control) and i would say that your cpu usage will decrease IF that's what causing  high cpu process in the first place?
On a side note - you have directed broadcast enabled?
res
Paul
Kind Regards
Paul
jkilleda
Level 3
Level 3
You can use the traffic storm control feature to prevent disruptions on Layer 2 ports by a broadcast, multicast, or unknown unicast traffic storm
