Link State Tracking on 6500 Switch
fadi4alpha
which ios version I have to install on 6500 Switch to be able to configure "link state tracking" feature ?
I was looking for this command in "Command Lookup" tools but without any results but I can configure this feature with the previous command on 3750 Switch !!!!!
Giuseppe Larosa
Hello Fadi,
may you provide a context?
are you trying to use Flexlinks, or you would like to track an object for example to use reliable static routing?
Hope to help
Giuseppe
ricarrar
Hello Fadi!
Link state tracking (as it's implemented on the 3750) is not supported on the 6500.  You should be able to do what you want with EEM though.
Richard
