Linking 2 switches
Rick Lowe
I have two SG200-50 switches.  They are located on separate floors and linked by one cat 5e cable.  If I pulled another cat 5e cable between the cabinets can I configure a LAG or something to achive a 2 MB link?
Rick
Yes it needs to be configured at both ends (or it does on Catalyst switches anyway).
If you need help with the setup there is a Small Business Forum where they deal with these switches so you could move this post to there -
https://supportforums.cisco.com/community/netpro/small-business/switches?view=discussions
Jon
6 Replies 6
Dear Rick,
               Yes, u can go with LAG and also it is called Etherchannel. It is a best way to go with this.
Etherchannel configuration guide example is follows:
               http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3550/software/release/12-1_13_ea1/configuration/guide/3550scg/swethchl.html
Note: EtherChannel frame distribution uses a Cisco-proprietary hashing algorithm.
Thanks and regards,
Chandhuru.M
Thanks and regards, Chandhuru.M
Thank you Chandhuru.  Can you tell me if this must be configured on both switches?
Thank you.
Rick
Jon
Dear Rick,
               Sorry for delayed reply.
               As Jon said, have to configure in both end of switches.
               Also refer this link,
http://www.orbit-computer-solutions.com/EtherChannel-Configuration-on-Cisco-Switches.php
Thanks and regards,
Chandhuru.M
Thank you Jon...worked perfectly.  I will post in the small business forum from here on.
Dear Rick,
                    In addition to your knowledge i would like to share small configuration for Etherchannel in Packet Tracer. Please find the attachment.
Thanks and regards,
Chandhuru.M
