Linksys E1000 --- OK for Netflix??
garfieldbd
Hi everybody.
My apologies if I've posted to the wrong forum.  I've been streaming Netflix through my Wii (wirelessly).  Yesterday, my router died.  I picked up the Linksys E1000.  However, I'm not able to stream Netflix anymore.  All the other functions on the Wii work (internet channel, shopping channel, etc...).  The wireless internet connection checks out OK on the Wii and my laptop.  My question is this:  Should I be able to stream Netflix through the E1000, or do I need to upgrade?  I thought a router was a router.  Since I started trying to troubleshoot, I found a few forums that are leading me to believe this may not be the case, that I may need to buy a router that allows streaming.
Any input would be appreciated.  Thanks.
Brian
paolo bevilacqua
Yes, you should be able to.
There is another section called "small business", try asking there for better help.
paolo bevilacqua
