Linksys SRW console cable
karamak2
Hi All,
I have a couple of Linksys SRW switches, that I need to login to verify some configurations. I tried two different Female to Female adapter cables and does not work. I do not think I have the proper console cable for them. Can someone guide me the right cable and where I can find them to purchase.
I have one, but does not work. Also, I changed the putty settings to below and still does not work.
38400 baud, 8 data bits, no parity, 1 stop bit, no flow control
karamak2
can someone pls help??
devils_advocate
Level 7
Level 7
Have you tried the other Baud rates?
Even if 38400 is the default, it could have been changed.
9600 and 115200 are fairly common.
Does the switch not have a management IP? Those switches have a GUI and I think they support Telnet also.
yeah, i tried other baud rates. Not sure about the switch management IP. I just took over and not given those details.
