Linlk speed
prashantrecon
We have leased line connectivity between router on one side and firewall on other side.Speed is 10Mbps.
Now we have to increase it to 20Mbps can router and firewall is capable of handling it.
Please find the details of device.
Cisco router details
Cisco IOS Software, 2800 Software (C2800NM-IPBASEK9-M), Version 12.4(24)
667648 bytes available (63348736 bytes used)
Firewall details
Cisco Adaptive Security Appliance Software Version 8.2(4)
Device Manager Version 6.4(1)
Hardware:   ASA5520, 512 MB RAM, CPU Pentium 4 Celeron 2000 MHz
Internal ATA Compact Flash, 256MB
255426560 bytes total (211197952 bytes free)
6 Replies 6
JohnTylerPearce
Level 7
Level 7
The integrated services routing architecture of the Cisco 2800 Series provides the performance, availability, and reliability needed to scale mission-critical business applications in the most demanding environments.
Features of the routers include:
  • Built-in security
  • Cisco Configuration Professional (CCP) for simplified management
  • A modular platform with a broad range of interface options
  • Up to 2 10/100/1000 Mbps built-in routed ports
  • Up to 64 10/100 Mbps switch ports with optional Power over Ethernet (PoE), for providing DC power to network devices such as IP phones
  • Up to 1500 VPN tunnels
  • Cisco CallManager Express (CME) call-processing support for up to 96 Cisco IP phone users
  • Cisco Survivable Remote Site Telephony (SRST) support for up to 96 Cisco IP phone users, allowing the router to provide call-processing functionality to keep voice service in operation should the connection to Cisco CME be lost
  • Support for wireless LAN standards 802.11a/b/g
  • Support for a Small Form-Factor Pluggable (SFP) port for Gigabit Ethernet (except 2801)
  • Built-in redundant power supply connector (except 2801)
Hi Prasanth,
You are well fine with the both devices Cisco 2800 and ASA5520.
As said above Cisco 2800 is cable to handle wan links up to 60 mbps for example.
And ASA5520 (Datacenter device) is cable of 720 Mbps throughput.
Please rate the helpfull posts.
Naidu.
Hi ,
Did you have any Cisco document which mention its speed ?
I already have a look of Cisco 2811 data sheet but in that max throughput put or max bandwidth not mentioned.
Prashant
Hi Prasanth,
Please see the below link for Cisco 2800. It can handle morethan the throughput what I mentioned in my previous post.
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/ps5882/product_data_sheet0900aecd8016fa68_ps5854_Products_Data_Sheet.html
See the below link for ASA 5520.
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/product_data_sheet0900aecd802930c5.html
Naidu.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
20 Mbps (duplex) is borderline for a 2811.  I've attached a Cisco document that lists performance for various routers.  In this document, you'll see a 2811 CEF performance is listed as 61.44 Mbps.  You need to divide by 2 to allow for duplex, and also need to allow for "other stuff" using the CPU.  Both bring the capacity down.  On the other hand, typical sized packets allow a higher rate.  That noted, I've seen a production 2811 max out at about 20 Mbps duplex.
