Showing results forĀ
Search instead forĀ
Did you mean:Ā
Linux/Unix networking
levijj0909
This  will test your practical Linux/Unix networking skills. A series of screen shots with commentary of the required tasks is to be submitted. The submission has to include an explanation of the tasks all the commands used and the output (or final result) of the task.
You are expected to research the necessary commands by themselves. There are numerous web sites available that discuss Linux networking. You are expected to list your sources of information for the different tasks.
The tasks will include the following
• Subnetting a small network;
• Setting up this network, configuring all the host interfaces as well as enabling routing;
• Use ping and traceroute to prove connectivity between your hosts;
• Configuring network services.
Hi guys
I am getting stuck with this particular question, could anyone give my a hand on? Thx!
Levi
Jon Marshall
Levi
What exactly are you stuck on ?  These forums are Cisco forums not unix.
Is it the actual commands to implement on unix system ?
Jon
