06-09-2007 05:48 PM - edited 03-05-2019 04:36 PM
I'm reading the documentation (http://www.cisco.com/application/pdf/en/us/guest/products/ps6238/c1067/ccmigration_09186a00808143a3.pdf) which specifically has a section on how to configure LLDP on a CGESM p-Class bladeSwitch. However, I'm unable to configure the switch for LLDP. The switch acts as if it doesn't have that feature.
EDIT: We also have a c-Class and LLDP works there.
Below is the output of show ver and show lldp:
NDCE06BLDC3SW1#sh ver
Cisco IOS Software, CGESM Software (CGESM-LANBASE-M), Version 12.2(37)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 10-May-07 14:39 by antonino
Image text-base: 0x00003000, data-base: 0x00D40000
ROM: Bootstrap program is CGESM boot loader
BOOTLDR: CGESM Boot Loader (CGESM-HBOOT-M) Version 12.2(25r)SE, RELEASE SOFTWARE (fc)
NDCE06BLDC3SW1 uptime is 9 hours, 11 minutes
System restarted at 12:33:39 EDT Sat Jun 9 2007
System image file is "flash:cgesm-lanbase-mz.122-37.SE/cgesm-lanbase-mz.122-37.SE.bin"
Host configuration file is "tftp://10.1.100.56/banner"
cisco 371098-001 (PowerPC405) processor (revision A0) with 118784K/12280K bytes of memory.
Processor board ID FOC0907902A
Last reset from power-on
2 Virtual Ethernet interfaces
24 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:13:19:C2:29:80
Motherboard assembly number : 73-9666-08
Motherboard serial number : FOC09042ZSP
Model revision number : A0
Motherboard revision number : A0
Model number : 371098-001
Daughterboard assembly number : 73-9697-04
Daughterboard serial number : FOC090430EE
System serial number : FOC0907902A
Top Assembly Part Number : 800-25741-01
Top Assembly Revision Number : A0
Version ID : V01
Daughterboard revision number : A0
Hardware Board Revision Number : 0x02
Switch Ports Model SW Version SW Image
* 1 24 371098-001 12.2(37)SE CGESM-LANBASE-M
Configuration register is 0xF
NDCE06BLDC3SW1#show lldp
% Invalid input detected at '^' marker.
NDCE06BLDC3SW1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
NDCE06BLDC3SW1(config)#lldp run
06-15-2007 10:25 AM
Link Layer Discovery Protocol (LLDP) and LLDP Media Endpoint Discovery (LLDP-MED) for interoperability with third-party IP phones. VLAN aware port security option to shut down the VLAN on the port when a violation occurs.
Please click following URL:
