lldp modes question
Tarek_ie
hello team
please whats the difference between this two commands
IC>lldp receive
IC>no lldp transmit
regards
Hi, as explained here
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/46sg/configuration/guide/Wrapper-46SG/swlldp.html
you can configure your device to selectively not to send and receive LLDP packets with the
no lldp transmit and no lldp receive commands.
If you want to receive or transmit LLDP packets again, you must use the commands lld receive and lldp transmit.
Regards.
thanks Daniele Giordano for ur reply well if i want to configure lldp to receive only (and dont send lldp packets) which command should i use
As you wrote initially
lldp receive    ### to allow receiving
no lldp transmit    ### to disable transmitting of lldp messages
Regards.
