LLQ on Cisco 4900M
pawanjit.chawla
We have a 1 Gbps link to a 4900M, over receive one stream of multicast and two streams of TCP traffic on the same port.
Stream1 - multicast
Stream2,3 - TCP
The multicast is capped at 40 Mbps from the source, the TCP bandwidth is capped at 10 Mbps for each stream. Since the link is not saturated, is there any benefit in creating a policy for each stream, and (since we want to minimize the delay for TCP traffic) give the TCP streams higher priority?
Also is LLQ functionality available over Ethernet interface in 4900M?
Any information on this would be helpful.
Pawan
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
If traffic is controlled such that your interface won't see congestion, no real advantage to adding any prioritization policy.
Not 100% sure with the 4900M, but it probably supports PQ on one of its hardware interface queues.
