Load Balance WAN
marcio.tormente
Level 4
Level 4
People,
How to configure load balance with two link serial into same router?
This links go out for internet.
5 Replies 5
Richard Burts
Marcio
The most simple and frequently best was to load share over 2 serial links is to configure 2 static default routes, one static default route pointing at each serial interface (or next hop address over the serial interface).
Rick
Rick
Rick,
Thanks for your answer, but this not possible because that link go out for internet and need use NAT.
I tried this, but he did not function.
Do you have another sugestion?
Marcio
NAT does not need to intefere with using static default routes. What was the problem?
Rick
Rick
Rick,
If i not use NAT, i can?t go out for internet.
I try again
