MAC address for Serial Interface
J_Vansen_S
Level 3
Level 3
Does a mac address for serial interface exist? If so, how can i look for it in a router?
I believe Serial operates at the Layer 2.
CSCO10892433
Level 4
Level 4
Hi, J_Vansen_S
Only 802.3 frame uses MAC address; and a serial port is typically encaped by hdlc, ppp or frame-relay. All these types of frames don't use MAC address. So, you won't see the MAC address on a serial port.
SSLIN
GillieLucent
Only LAN interfaces like ethernet, FDDI interfaces uses MAC address.
Serial interfaces don't use MAC address, since its directly connected to the peer.
In HDLC-like serial interfaces, the Address field is a single octet, which contains the binary sequence 11111111.
For more information,
read RFC 1661- The Point-to-Point Protocol
Vijaybabu
