Load balancing a cisco ASA
carl_townshend
hi all , can anyonne tell me if its possible to load balance a cisco asa in transparent mode ?
cpembleton
Level 4
Level 4
I'm assuming you mean with multiple interfaces.
The answer is no. Each context/single mode can only have 2 data interfaces and 1 management port if available. If you have a 6500 you could always use FWSM.
Chad
Please rate post if this helps!
