Load balancing and automatic fail over of traffic
collinks2
Level 5
Level 5
Hello Guys, We want to accomplish this using Cisco 2911 router. We have the following networks: 172.16.2.0,172.16.3.0 - 172.16.7.0.
Our goal is to allow all these network to use the two isp links. If one isp link goes down, those network will be redirected to another isp link. All the lan networks must make use of the two links.
Access list is nat-add
Isp1 pool is mtn and isp2 pool is airtel
Route map for  isp1is route-mtn
The route map statement matches the access-list nat-add with the next valid hop set to the gateway pointing to isp1
route-map for isp2 is route-airtel.
What access - list statement do we use for the isp2 since the route-map for isp1 is matching all the networks in the access-list, nat-add?
How do we define the ip sla monitor using track command in the default router? I know we will have two default routes, one pointing to isp1 and the other pointing to isp2?which default route will use the track command?
Any suggestions will be appreciated
28 Replies 28
Francesco Molino
Sorry but I'm not sure I get your point.
you have 2 ISPs and 3 LAN subnets : 172.16.2.0,172.16.3.0 and 172.16.7.0, is that right?
What trigger the traffic to go to ISP1 or ISP2? Will that be triggered by protocol (like http, ftp on 1 link and all others on another link)? Or will that be based on source IP or ....?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco,
Sorry that I didn't reply your questions.The lan subnets are :
172.16.2.0
172.16.3.0
172.16.4.0
172.16.5.0
172.16.6.0
172.16.7.0
All the subnets are expected to make use of isp 1 and isp 2 links at the
same time. If either of the links fails, it goes to another.
Georg and Paul have provided wonderful suggestions
both route maps need to match the same ACL, just the matching interfaces need to be different.
You need to track both routes, because either one might go down.
Post the full configuration, so we can add the necessary bits and pieces...
Hello
Given the your requirements the config below maybe  applicable -
Apply sla to poll a wan address sourced from your primary wan interface
ip sla 1
 icmp-echo 8.8.8.8 source-interface X/X <primary interface>
ip sla schedule 1 life forever start-time now
track 1 rtr 1 reachability
create ACL and NAT statements for dual wan links
access-list 100 permit ip 172.16.2.0 0.0.1.255 any
access-list 100 permit ip 172.16.4.0 0.0.3.255 any
route-map LAN permit 10
 match ip address 100
 match interface <primary interface>
route-map LAN2 permit 10
 match interface <secondary interface>
ip nat inside source route-map LAN interface <primary interface> overload
ip nat inside source route-map LAN2 interface <secondary interface> overload
Apply default static routes to primary and secondary wan links with tracking and admin distances values
ip route 0.0.0.0 0.0.0.0  x.x.x.x  1 name Primary track 1
ip route 0.0.0.0 0.0.0.0 y.y.y.y. 200
res
Paul
Kind Regards
Paul
My config is almost the same with Paul except in subinterfaces where I
enabled policy Based routing
ip sla 1
match interface
match interface
ip nat inside source route-map LAN interface overload
ip nat inside source route-map LAN2 interface overload
Georg suggested that we should enable track
for the two default routes.
The primary default router carries track 1 should I use another track no
for the secondary router.
Paul put administrative distance of 1 for the primary and 200 for the
secondary. The secondary will take over only if the primary fails. We don't
want the secondary to be redundant. We want the two to be up at the same
time.
According to Georg suggestion, it seems the two routes will have the same
administrative distance but different track nos.
Is there no need for policy Based routing? Will this be enabled on each
subinterface or the physical interface. I will post my configuration
tomorrow.
if you want load balancing, you need both default routes to be up. They both need to be tracked. I would also install an EEM script that clears the NAT translations in case one of the links goes down, or, as an alternative, set the 'ip nat translation timeout' to a real low value.
So, the entire config could look like this:
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
ip sla 1
ip sla 2
icmp-echo 8.8.8.8 source-interface Y/Y
ip sla schedule 2 life forever start-time now
match interface x
match interface y
ip route 0.0.0.0 0.0.0.0 x.x.x.x track 1
ip route 0.0.0.0 0.0.0.0 y.y.y.y. track 2
event manager applet IP_SLA1_DOWN
event track 1 state down
action 1.0 cli command "enable"
action 2.0 cli command "clear ip nat translation forced"
event manager applet IP_SLA2_DOWN
event track 2 state down
Hello Georg,
Can you add event scripts for the states that are up? Is there no need for
that?
Hello
"We don' want the secondary to be redundant. We want the two to be up at the same time."
Then I would suggest to still use a primary default with the track and admin option for you default traffic and ALSO incorporate PBR for the certain lan subnets you wish to utilize the secondary ISP link
As such then the configuration will need to incorporate  PBR with Tracking
Please review my post from this ticket - here
res
Paul
res
Paul
Kind Regards
Paul
Hello Paul driver,
I have read the post in that ticket. However, I will ask questions in that
thread. For this thread, there is something I need you to clear me on.
icmp-echo 8.8.8.8 and
icmp-echo source-ip
What is the difference between the two cos 8.8.8.8 is a public DNS server
while the source-ip is ip address of the wan interface of the router?
Hello
@collinks2 wrote:
Hello Paul driver,
icmp-echo source-ip
Icmp-echo <destination ip of host you would like to poll  source-ip/interface <source you wish to orignate poll)
I just used google dns as an example, However you would poll a prefix you know resides off/ is reachable from your primary wan interface
res
Paul
Kind Regards
Paul
OK. In a scenario, where I have subinterfaces, will PBR be enabled on the
physical interface or on each subinterface.
Also, assume I want to achieve the following scenario with reference to
that previous ticket whose link you attached in your previous comment on
this thread
All the http and https traffic will be routed via isp1
All other traffic will be routed via isp2
In the above scenario, I would create two access list
1 . access-list 100 permit tcp 172.16.2.0 0.0.3.255 any eq 80
access-list 100 permit tcp 172.16.4.0 0.0.7.255 any eq 80
access-list 100 permit tcp 172.16.2.0 0.0.3.255 any eq 443
access-list 100 permit tcp 172.16.4.0 0.0.7.255 any eq 443
2. access-list 101 permit ip 172.16.2.0 0.0.0.3.255 any
access-list 101 permit ip 172.16.4.0 0.0.7.255 any
For the route map statement
route-map PBR permit 10
Match interface isp 1
route-map PBR permit 20
match ip address 101
match interface isp2
Int Y/Y (the physical lan interface)
ip policy route-map PBR
etc
Update :
My nat statements for the above scenario that filters traffic would be
access-list 102 permit ip 172.16.2.0 0.0.3.255 any
access-list 102 permit ip 172.16.4.0 0.0.7.255 any
(ignore the error in the wild card bit, it should be 172.16.2.0 0.0.1.255
and 172.16.4.0 0.0.3.255. I can still use a summarized route so that I have
one statement in the access-list 102)
match ip address 102
match interface y/y
LAN2 permit 10
match interface y/y
Hello Paul driver ,
In case a company policy states that "all the http and https traffic from all users should route across isp1 (slower internet connection) while all other ip traffic should be allowed to route across isp2 (faster internet connection)
see the attached config file which i did with reference to the one you posted in another thread.
thanks in anticipation
casanavep
Level 3
Level 3
I would add that a single match on IP SLA is not very reliable.  8.8.8.8 and other global DNS providers often filter ICMP, so a dual positive usually prevents path stability issues.  Also, since you need both default routes to be removed during their individual outage and load balancing to occur, you need something more complex.
Dual Match with clean failover (make sure it is really down or up before dropping):
Path 1 validation:
 delay down 15 up 60
 delay down 15 up 60
! (or means the track will be up if one "or" the other is up)
track 3 list boolean or
 object 1
 object 2
ip sla 1
 icmp-echo 8.8.8.8 source-ip {CE Internet interface #1 IP}
 threshold 1000
 timeout 1000
 frequency 5
ip sla 2
 icmp-echo 4.2.2.2 source-ip {CE Internet interface #1 IP}
 threshold 1000
 timeout 1000
 frequency 5
!----- Path 2 validation------:
track 5 ip sla 5 reachability
 delay down 15 up 60
track 6 ip sla 6 reachability
 delay down 15 up 60
track 7 list boolean or
 object 5
 object 6
ip sla 5
 icmp-echo 8.8.8.8 source-ip {CE Internet interface #2 IP}
 threshold 1000
 timeout 1000
 frequency 5
ip sla schedule 5 life forever start-time now
ip sla 6
 icmp-echo 4.2.2.2 source-ip {CE Internet interface #2 IP}
 threshold 1000
 timeout 1000
 frequency 5
ip sla schedule 6 life forever start-time now
!  ---- Load balanced routing
ip route 0.0.0.0 0.0.0.0 {ISP#1 PE IP} 100 track 3
ip route 0.0.0.0 0.0.0.0 {ISP#2 PE IP} 100 track 7
!   failover route, just in case you IP SLA fails to function as desired and you need a back door
ip route 0.0.0.0 0.0.0.0 {ISP#1 PE IP} 200
let us know how this is working our for you.
Cheers,
