Load balancing & reduncey with 2 Pri Lines
Srinivas N
Dear Friends.......
I have a requirement of VOIP setup and I have 2 Pri Lines of MPLS cloud.
I have 3 r routers, router1 is for IPS 1 (Pri 1), router 2 is for ISP 2 (Pri 2) and router 3 is for Load balancing.
plz explain me how to config load balancing & redundancy....
my another question is E1 Leased line will cupport voip?
ISP 1 IP_172.16.10.1/24
ISP 2 IP_170.16.5.1/24....
Plz explain with config,....
Thanks & Regards,
Srinivas. N
Thanks & Regards,
Srinivas.
acampbell
Can you explain about the 3 x PRIs are they for placing voice calls to the PSTN or are they
dial-up WAN services ?
Normally if they are for the likes of Cisco Call Manager for PSTN calls then you would set up the hunting method for redudancy via the CUCM route lists/route groups/gateways
Alex
Regards, Alex. Please rate useful posts.
Hi Alex
Sorry, I have 2 PRIs,  PRI one is for main line & PRI two is for backup line, both should work as a load balancing...  they are for placing voice calls to the PSTN ..
My concept is I have 3 routers... Router 1 is for PRI one, Router 2 is for PRI two & Router three is for load balancing...
Plz explain me how to config three router...
I hope In router one need to config with pri voice channels, In router two need to config with pri voice channels & In router three need to config load balancing...
Thanks & Regards,
Srinivas. N.
Thanks & Regards,
Srinivas.
