Unable to connect to Access Point over VLAN
JOE HARRINGTON
I have a Cisco Aironet 1142 that I am unable to ping or connect to in order to manage and unable to connect to the SSIDs .  I have changed the native VLAN to 318 on the 1142.  I have also set the port on my 3750X to trunk with the native VLAN set at 318.  The 1142 can ping its IP address but not the Default Gateway.  The switch is able to ping the Default Gateway but not the 1142.  Any suggestions based upon the configs included below?  Many thanks!
Aironet 1142:
interface Dot11Radio0.318
 encapsulation dot1Q 318 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio1.318
 no ip route-cache
 bridge-group 1
interface GigabitEthernet0.318
 no ip route-cache
 bridge-group 1
interface BVI1
 ip address 172.17.18.200 255.255.255.0
 no ip route-cache
ip default-gateway 172.17.18.1
3750X:
interface GigabitEthernet1/0/30
 switchport trunk native vlan 318
 switchport trunk allowed vlan 3,318,956
 switchport mode trunk
 switchport nonegotiate
 switchport voice vlan 220
 srr-queue bandwidth share 1 30 35 5
 priority-queue out
 mls qos trust device cisco-phone
 mls qos trust cos
 auto qos voip cisco-phone
 spanning-tree portfast
 service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
Jan Rolny
Level 3
Level 3
just for clarification you are pinging 172.17.18.1 right?
Is interface wiht this IP address UP ?
Can you please post sh interface status  and  sh ip interface brief ?
Jan
Yes, unable to ping 172.17.18.1.  BVI interface is up
#sh int bvi1
BVI1 is up, line protocol is up
  Hardware is BVI, address is e8b7.48f5.0f7e (bia e8ba.70e7.d430)
  Internet address is 172.17.18.200/24
  MTU 1500 bytes, BW 54000 Kbit/sec, DLY 5000 usec,
  Last input 03:18:25, output never, output hang never
     133 packets input, 9926 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     1610 packets output, 189086 bytes, 0 underruns
     0 unknown protocol drops
output you provided is from AP. Could you please post output of command from switch? There will be probably problem in configuration or something else.
Also please check cable connection it sometime also make some issues.
Jan
We found the issue.  It was a VLAN tagging problem on the switch.  Thanks for the help.
