Load balancing routing table
sathish.ippani
Hi Everyone,
As per the attached network diagram, we have 5 remote sites(10.10.0.0/16, 10.20.0.0/16, 10.30.0.0/16, 10.40.0.0/16 and 10.50.0.0/16) and data center (10.1.0.0/16, 10.2.0.0/16).
Remote sites are connected with two ISP to data center.
We have a requirement as follows,
From site1, data center subnets should use level3 (BGP) and other traffic includes remote sites and Internet should use Sprint (EIGRP)network. and incase any ISP fail, all traffic should fail over to other isp.
Please let me know how can I achieve this requirement.
Reza Sharifi
Are all the connections between the remote sites and the data center point-to-point lease lines?
Does the internet connection comes to the data center only?
Are both Sprint and Level-3 providing you Internet access?
Level3 and sprint are MPLS links and there are 3 P2P links between site 3 to datacenter, site4 to data center and site5 to site4 are P2P link.
remote site access internet via sprint and if sprint fails they use level3 and P2P links to access internet via Datacenter.
Only sprint provided internet
