load balancing traffic
carl_townshend
Hi all quick question, If I have a main router with dual ip on the interface, and 2 other local routers one in each subnet, If I have 2 static routes on the main router pointing the same dest to both routers, will it load balance by source address, so all the dest traffic will route on its own subnet effectively ?
spremkumar
Level 11
Level 11
Hi Carl
Do post out a topological diagram on how the routers are connected and whats beyond the the dual routers ..
That will help in suggesting the traffic flow in and out through the dual routers..
regds
Hi Carl,
Do the Other Local Router's Connected directly to the Main router. A diagram will be very useful.
Danny
the other routers dont connect directly, they sit off a switch but yes both routers sit on one of each subnets set on the fe interface !!
