load balancing using bgp multihop relax
Haris P
Level 4
Level 4
Dears ,
I'm using the command BGP multihop relax to lead balance between two of my ISP connections . The scenario is explained in the below link
http://blog.alwaysthenetwork.com/tutorials/bgp-multipath-relax/
the traffic seems to be not load balancing properly with this setup . Both routes are showing in the routing table .What could be the possible reasons >?
haris
Mahesh Gohil
Level 7
Level 7
Hello Haris,
Even with the command you used there is need of same AS length though both path is different.
Can you verify the length of number of AS's both path contain.
you can post more output from your router for better understanding
Mahesh
Dear Mahesh ,
The AS path length is same in both cases
-Router>sh ip bgp
Network Next Hop Metric LocPrf Weight Path
  • 10.1.1.0/24 192.168.111.93 0 76677 64546
64546 i
*> 172.31.247.101 0 64852 64852
64546 i
  • 10.1.10.0/24 192.168.111.93 0 76677 64546
64546 ?
64546 ?
  • 10.1.20.0/24 192.168.111.93 0 76677 64546
64546 ?
64546 ?
  • 10.1.24.0/24 192.168.111.93 0 76677 64546
64546 ?
64546 ?
  • 10.1.35.0/24 192.168.111.93 0 76677 64546
64546 ?
64546 ?
  • 10.1.37.0/24 192.168.111.93 0 76677 64546
64546 ?
64546 ?
  • 10.1.39.0/24 192.168.111.93 0 76677 64546
64546 ?
64546 ?
  • 10.1.40.0/24 192.168.111.93 0 76677 64546
64546 ?
64546 ?
  • 10.1.41.0/24 192.168.111.93 0 76677 64546
64546 ?
64546 ?
HI,
Can you post output of "sh ip bgp " output
Mahesh
