Load Balancing Using Port Channels
rootswitch
The Cisco Nexus 9000 Series NX-OS Interfaces Configuration Guide, Release 10.5(x) tells at chapter Load Balancing Using Port Channels:
"Configuring hash load balancing applies to unicast and multicast traffic on Cisco Nexus 9200, 9300-EX, and 9300-GX Series switches."
It sounds so strange that 9300-FX series is not mentioned. Can someone explain why? Does that configuration guide section apply to 9300-FX series as well?
If thereis no restrictions then it apply to all NSK SW series.
MHM
Mark Elsen
          - Check whatever the port-channel load-balance ?   command lists as options
             on the 9300-fx platform.
   M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
If I had the 9300-fx platform available I think I would have not asked Thanks anyway for suggesting.
@rootswitch    Since  the device runs nx-os  too, you will have the same options available as on the other models,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
