Load Balancing with server cpu utilization
Alex Pfeil
Level 7
Level 7
I was just wondering if there is a cisco way to set up load balancing for a server farm, and base the balance off of cpu utilization on the servers?
Joseph W. Doherty
I don't know for Cisco SLBs in particular, but I believe some SLBs watch how responsive servers are. They then balance based on response performance. If such a feature is supported, it might even better satisfy your requirement if you're thinking is busy CPU makes for slower response. Since CPUs vary in performance, just looking at CPU load could work against you. E.g. a 50% load on a very fast CPU might be better than a 25% load on a slower CPU.
