Load related stack master re-election? 3750
droberts1214
We're working to pinpoint the cause of a stack master re-election.
Here's the scenario:
Setting all ports on a 3750 48 port switch to vlan dynamic, using the int range command, 24 ports at a time.
Enter configuration commands, one per line.  End with CNTL/Z.
OTCSTACK5(config)#int range Fa2/0/1 - 24
OTCSTACK5(config-if-range)#switch acc vlan dynamic
Jun 22 20:12:31: VQPC PAK:
Jun 22 20:12:31: VQPC PAK: HRPC HANDLER rcvd 74 bytes from box 1:
Jun 22 20:12:31: VQPC: rcvd HRPC_REQ_VQP_QUERY from box 1
Jun 22 20:12:31: VQPC PAK: xmt transaction ID = 0x000000B1
Jun 22 20:12:31: VQPC PAK: sending query to VMPS
Jun 22 20:12:31: VQPC PAK: rcvd packet from VMPS
Jun 22 20:12:31: VQPC PAK: transaction ID = 0x000000B1
Jun 22 20:12:31: VQPC: Master sends HRPC_REQ_VQP_RESPONSE to slave 1
Jun 22 20:12:31: VQPC PAK: HRPC HANDLER rcvd 16 bytes from box 1:
Read from remote host 10.0.0.165: Connection reset by peer
Connection to 10.0.0.165 closed.
30 seconds later we are able to reconnect and get:
OTCSTACK5#conf t
OTCSTACK5(config)#int range f2/0/1 - 24
Command suspended while switch(es) are being added to stack...
OTCSTACK5(config-if-range)#end
a quick show switch shows
Switch#  Role   Mac Address     Priority Version  State
*1       Master 001b.2b11.5300     1      0       Ready
2       Member 001b.2b11.5380     1      0       Ready
3       Member 001a.e37d.6a80     1      0       Ready
4       Member 001d.4654.6880     1      0       Ready
This is the prior stack master election
1       Member 001b.2b11.5300     1      0       Ready
*3       Master 001a.e37d.6a80     1      0       Ready
Switch 3 was the stack master, switch 1 is now the current.
No power loss, no reboots.
It looks to me like the most probable cause would be a cpu load related re-election, which is somewhat concerning.
Has anyone experienced anything similar to this? Anyone able to shed any additional light on it?
Any assistance would be appreciated.
Leo Laohoo
Try manually setting the stack master using the command "switch # priority 15".
