Log messages not appearing on telnet
jeff113113
When I console into the my 3550 and 3560 switches i'm not able to see the messesage appear if a interface goes down. But If I use a putty session and telnet into my directly connected (i can't see the logs only on a sh log) or  telnet into the other switches from that switch I'm only able to see the logs by issuing a show log.
JohnTylerPearce
Level 7
Level 7
Type in 'term mon' and hit enter, let me know if this fixes the issue.
JohnTylerPearce
Level 7
Level 7
i'm enter this command on cisco 4500.but switch cant  show log messages.switch  just shows this log
(3w3d: %C4K_IOSMODPORTMAN-6-POWERSUPPLYFANGOOD)
John Blakley
In addition to what johns stated, be careful doing a term mom for certain debugs. They can crash your telnet session if there's too much data. You mentioned tat you also aren't seeing log messages on the console. If you're wanting to, make sure you have 'logging console ' enabled.
Hth,
John
HTH, John *** Please rate all useful posts ***
