Log Msg Interface:GigabitEthernet2/17 speed changed
Gilbert Armour
My Catalyst 4507 has started posting the following message in the log file.  It occurs for several ports on line cards 2 and 5 with varying speeds of 10, 100, and 1000 kbs.  Is this normal or indicate possible issues?  Both line cards were recently replaced, but the messages started before they were replaced.
Dec  2 11:12:50.804: Interface:GigabitEthernet5/32 speed changed to 1000000 kbps. Policymap: AutoQos-VoIP-Output-Policy is updated
Reza Sharifi
Are you running Auto-QOS?
What if you change the config from Auto-QOS to just manually applying QOS and see if the log message goes away?
Not really sure.  sho auto qos lists almost every physical interface with auto qos voip cisco-phone and sho runn | begin int shows physical interfaces with service-policy defined for both input and output.  Very few ports connect Cisco VOIP phones, most are student PCs.
To me it may be doing both auto and manual QOS?
The ports involved include the following commands, which may be duplicating or conflicting? I inherited this network and not familiar with the history of the configuration.
qos trust device cisco-phone
service-policy input AutoQos-VoIP-Input-Cos-Policy
service-policy output AutoQos-VoIP-Output-Policy
  Policy Map AutoQos-VoIP-Input-Cos-Policy
    Class AutoQos-VoIP-Bearer-Cos
      set qos-group 46
    Class AutoQos-VoIP-Control-Cos
      set qos-group 24
  Policy Map AutoQos-VoIP-Output-Policy
    Class AutoQos-VoIP-Bearer-QosGroup
      set dscp ef
      set cos 5
      priority
     police cir percent 33
       conform-action transmit
       exceed-action drop
    Class AutoQos-VoIP-Control-QosGroup26
      set dscp af31
      set cos 3
      bandwidth remaining percent 5
    Class AutoQos-VoIP-Control-QosGroup24
      set dscp cs3
      set cos 3
    Class class-default
      dbl
