Logging Buffered Commands
ashleyreed4218
Level 2
Level 2
Hello All,
Just a quick question. When implementing a syslog server and ACL's, is it necessary to choose the logging buffered commands?
Exe:
Logging Buffered Commands:
Message                   Severity Level
<0-7>                       Logging severity level
<4096-2147483647>    Logging buffer size
alerts                Immediate action needed                          (severity=1)
critical               Critical conditions                                  (severity=2)
debugging              Debugging messages                    (severity=7)
emergencies           System is unusable                         (severity=0)
errors                 Error conditions                                (severity=3)
informational          Informational messages                   (severity=6)
notifications          Normal but significant conditions    (severity=5)
warnings               Warning conditions                                  (severity=4)
My colleague thinks that there is a Cisco default and we don't need to include these.
Thank you in advance,
Ashley
Reza Sharifi
The is an optional command if you are logging locally to the router or switch and not a syslog server.
Reza Sharifi
Thanks!
