Logging CBAC sessions
filippos111
Hi folks,
Is there any way to log the output under "Established Sessions" from the show ip inspect sessions command of a 2811 router? By logging i mean recording, or creating some sort of log file in a remote machine in the network.
Regards, Philipp
Cbac audt trail & real time alerts
conf t
ip inspect audit-trail
no ip inspect alert-off
logging on
logging x.x.x.x ( syslog server)
sh ip inspect config
res
Paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
cadet alain
you could use this to send the output in a text file on a server:
http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_s1.html#wp1041232
Alain
Thanks for the reply, though I guess the first post was a bit misleading:
From what i understand, your answer refers to copying the terminal output of a any show command, and trasnferring it to a specific url.
What i originally meant was for that information about established CBAC sessions to be automatically transferred to a file in a remote server as it is created, in order for someone to monitor the sessions without logging in to the router.
the only two logging features I know of are these:
"Q. What logging features are included with Cisco IOS Firewall?
A. Enhanced audit trail features use syslog mechanisms to track  transaction-session termination time stamps, source host, destination  host, ports used, and the total number of transmitted bytes. Real-time  alerts send syslog notifications to central management consoles upon  detection of suspicious activity. This setup gives network managers the  ability to respond immediately to intrusions."
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps5708/ps5710/ps1018/prod_qas09186a008010a40e.html
Alain
conf t
logging on
res
Paul
Kind Regards
Paul
