Logging Hostname Error
PolarPanda
Hi there,
         I want to send syslog of stack switch to syslog server, so I excuted command "logging server hostname". Here is error message I got: %ERROR: Standby doesn't support this command. I'm able to ping the hostname. Can anyone tell me how to fix the problem? Thank you!!
2 Accepted Solutions
Hi @PolarPanda ,
The command must be entered on the active switch.
Can you verify this?
or
logging host server hostname
I think the error message tells you this:
Hi @PolarPanda ,
Apparently, it's not like that:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_55_se/configuration/guide/3750xscg/swstack.html#60650
Connectivity to the Switch Stack Through an IP Address
The switch stack is managed through a single IP address. The IP address is a system-level setting and is not specific to the stack master or to any other stack member.
I suggest, if possible, connect via console cable to the active switch and try the mentioned commands.
10 Replies 10
balaji.bandi
Can you give us more information what is this device.
can you post
show verison
show switch
need to check where you are issue this command is standby, to confirm we need to know the above details.
BB
Here is the info:
Show version: Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.03SE RELEASE SOFTWARE (fc2).
Switch Ports Model SW Version SW Image Mode
* 1 56 WS-C3850-48P 03.03.03SE cat3k_caa-universalk9 INSTALL
2 56 WS-C3850-48P 03.03.03SE cat3k_caa-universalk9 INSTALL
3 56 WS-C3850-48P 03.03.03SE cat3k_caa-universalk9 INSTALL
Show switch
H/W Current
Switch# Role Mac Address Priority Version State
*1 Active 00e1.6d08.5100 15 M0 Ready
2 Standby 6cfa.8934.ff00 14 M0 Ready
3 Member 6cfa.8968.9d00 12 M0 Ready
I didn't copy all the result of show version. Please let me know what else do you want to see.
we have many 3850 running with below command :
logging host 10.10.10.10  <-- this is syslog server IP
make sure you are logging using SSH right ? (not on the console - if the console are you sure this is connected to Active switch - master in the stack)
BB
Hi BB,
            yes, i used SSH. I have no problem to type in ip address like you showed me, but I have error message when typing in hostname.
luis_cordova
Thank you Luis. I did try the command earlier, but I still have the same result.
Hi @PolarPanda ,
or
Hi Luis,
          I believe I connect to the active switch. Correct me if I'm wrong. I ssh in the switch with a ip address in management vlan. The only interface management vlan configured is active switch interface.
Hi @PolarPanda ,
Thank you Luis! I think I will stay with entering ip address instead of hostname since I have lots of more switches in different locations.
