Logging - %SSH-3-NO_MATCH: No matching cipher found: client aes128-cbc,blowfish-cbc,3des-cbc server aes128-ctr,aes192-ctr,aes256-ctr
jcone
So today I had an SSH session going to my ISR 3925 SEC/K9 running IOS version 15.7 and I suddenly lost the connection.  When I tried to reconnect I received the error in Putty stating that the connection was refused.  I quickly obtained a console connection to the device and this log message was logging consistently to the console.
After re establishing console access to the device I have tested the ssh via a remote site and testing completed successfully.
I am the only one who is trying to connect to the device that I am aware of.  This log message is awfully troubling to me, any ideas?
10 Replies 10
Reza Sharifi
Did you recently upgrade the IOS on this router? In some platforms, after an upgrade, SSH becomes unusable and so you have to redo the SSH key to get it working again.
No I haven’t.
Thanks for the advise Reza.
I did regenerate the RSA keys and power cycled the router, this did not help.  I Disabled SSH as an access protocol on the the vty line.  The logs are clean now but obviously I do not have remote access to the unit over ssh.
This may be a bug. The only thing I could find is a similar bug but associated with the 7ks and not your platform. Open a ticket with TAC and send them the logs.  This may be a known issue.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCut72659/?rfs=iqvred
I apologize in advance for resurrecting a dead thread..
The issue is that PuTTY is attempting to use block-chaining (aes128-cbc) whereas the IOS router is configured to only accept counter mode (aes128-ctr).
Either:
  1. Use a newer version of PuTTY that has CTR mode built in.
  2. Configure the IOS router to also offer/accept CBC mode:
    ip ssh server algorithm encryption aes256-ctr aes192-ctr aes128-ctr aes256-cbc aes192-cbc aes128-cbc
  3. If using Linux you can specify a cipher to use (if it's not part of the default algorithms offered):
    ssh -c aes128-ctr username@host
  4. If using NX-OS and you can access the bash shell, then you can update the /etc/ssh/ssh_config file to also use other encryption methods.
Hopefully that helps.
Cheers
Hi Guys,
Take in place the configuration below:
ip ssh server algorithm encryption aes128-cbc 3des-cbc aes192-cbc aes256-cbc aes128-ctr aes192-ctr aes256-ctr
It worked for me.
IOS  Version 15.0(1r)M12 - Router CISCO1905/K9.
Works for me too. thanks a lot
Thanks for the insight.  I will look into this one and keep you posted.
jvscampos
♥Solucação do Bug no acesso por SSH♥
O erro acontece pois o sistema operacional
não está conseguindo definir um perfil de
criptografia correspondente para a sessão
por SSH. (cifra correspondente)
Então você precisa fixar manualmente,
como vou mostrar abaixo:
Router# ssh -l "seu login" -c aes128-ctr
-p 22 "ip da máquina que você quer acessar aqui"
A criptografia pode ser esta: -c aes128-ctr
ou pode ser qualquer outra a qual a mensagem
de erro que aparece para você mostra
exemplo:
aes256-cbc server aes128-ctr,aes192-ctr,aes256-ctr
Depois é só inserir a senha e EURECA!
Você conseguiu! :)
rajatoutbox
Hello, This might be resolved. But to make it convenient for others too, I am adding a persistent solution.
My Use case & up
I am running the Ansible control node as a VM inside Proxmox. The same Proxmox is also running a GNS3 lab VM.
====> DOING SSH FROM ANSIBLE NODE TO CISCO vIOS NODE IN GNS3 LAB TOPOLOGY.
1.) On ansible node i did
   cd ~/.ssh
   ls -l
   #NO CONFIG FILE WAS PRESENT SO CREATED THAT
   touch config
   nano config
  # ADD THESE Lines TO THE FILE
Host < IP ADDRESS OF CISCO NODE HERE >
    KexAlgorithms +diffie-hellman-group14-sha1
Ctrl+x, hit y to save, and exit !
chmod 700 config
systemctl restart ssh
systemctl restart sshd
AND VOILA, YOU ARE GOOD TO GO! try logging in with ssh username@ipofcisconode
