11-27-2006 03:51 PM - edited 03-05-2019 01:02 PM
Hey Everyone,
What is the best way to log all network traffic. We have 30x 2950 switches and few C3550 with one acting as the core switch.
Kind Regards,
Mark
11-27-2006 07:14 PM
Use syslog to log your traffic.
Configure logging on switches and specify a logging server ip. And in the server install Kiwi syslog server.
Hope that helps.
Suresh Jain
11-27-2006 07:35 PM
In additon to above post you should also consider configuring the correct logging level as per your needs
have a look at this link
HTH, rate if it does
Narayan
