question on extended named ACLs
ericgarnel
Level 7
Level 7
This may seem like a simple question, but when creating named extended access-lists, is there a way to have them increment by 1 rather than ten? Without editing the ACL manually?
example:
10 permit any host 192.168.1.10 eq www
20 permit any host 192.168.1.10 eq 443
30 permit any host 192.168.1.10 eq ftp
40 permit any host 192.168.1.11 eq www
I would like to have ACL lines 10-19 for host 1, and ACL lines 20-29 for host 2 and so on..
2 Accepted Solutions
why don't you resequence it after building the ACL
ip access-list resequence Word-ACL 1 1
Hi Friend,
You can definitely do what you want.
Hava a look at this link.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1838/products_feature_guide09186a0080134a60.html
HTH, rate if it does
Narayan
glen.grant
I thought you could put any number you want in between say 10 and 20 or 20 and 30 etc. Try adding one with a number of say 21 , I think it will take it . Whether there is a way to set the default used by the router I don't know . In ACL config mode you just put the number you want in front of the statement.
Yes, it will take it. I am doing that already
what I do is create an ACL entry per host then
10 = 1st host, 20 = 2nd host, etc and then back fill for additional ACLs per host 21,22...
I am just looking for a way to be more efficient at it
Hi Friend,
Narayan
