logging
MZydorczyk2
Level 4
Level 4
Anyone have, or can easily get a list of options you can enable for logging on cisco switches in IOS and catos?
mohammedmahmoud
Level 11
Level 11
Logging on Cisco Routers/Switches can be done in one of these 4 methods:
1.Console logging - Enabled by default ("logging console" under the global configuration) - The logging will pop-up to the terminal when you are connected via console.
2.Monitor logging - Disabled by default - The current terminal line (to the vty (telnet) sessions when "terminal monitor" is enabled - to disable use "terminal no monitor" - Exec enable mode not configuration mode) - pop-up logging on your screen like in the first method but it is not enabled by default (needs the "terminal monitor").
3.Buffer logging - The router internal logging buffer (use "logging buffered" then "show logging" to display the logs saved in the logging buffer (local RAM Buffer), but the main drawbacks here is the limited size of the buffer (retains only the newest Information) and that the log is lost if the router reloads since it is in the RAM - the last constrain can work around by saving the logging buffered to the flash via the logging file command).
4.Syslog logging - The syslog server (use "logging ") the most preferred method, its only drawback is when the connectivity is lost with the syslog server.
On CatOS it is nearly identical:
4003 (enable) set logging ?
buffer Set logging buffer size
console Set logging console (enable/disable)
history Set logging history table size
level Set logging level
server Set logging server
session Set logging session (enable/disable)
timestamp Enable or disable logging timestamp
BR,
Mohammed Mahmoud.
Hi Mohammed,
Do you know (or someone knows) why several of my Cisco WS-C6509-E does not support "logging origin-id" command?
Cisco documentation explains that this command introduced in 12.2(15)T, and integrated into 12.2(33)SXH
switchb(config)#logging ?
  Hostname or A.B.C.D  IP address of the logging host
  buffered             Set buffered logging parameters
  buginf               Enable buginf logging for debugging
  cns-events           Set CNS Event logging level
  console              Set console logging parameters
  count                Count every log message and timestamp last occurance
  esm                  Set ESM filter restrictions
  event                Global interface events
  exception            Limit size of exception flush output
  facility             Facility parameter for syslog messages
  filter               Specify logging filter
  history              Configure syslog history table
  host                 Set syslog server IP address and parameters
  ip                   IP configuration
  listen               MWAM remote console and logging listen enabler
  monitor              Set terminal line (monitor) logging parameters
  on                   Enable logging to all enabled destinations
  rate-limit           Set messages per second limit
  reload               Set reload logging level
  source-interface     Specify interface for source address in logging transactions
  system               enable/disable System Event Log
  trap                 Set syslog server logging level
  userinfo             Enable logging of user info on privileged mode enabling
switchb(config)#
switchb#sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXH5, RELEASE SOFTWARE (fc1)
System image file is "sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXH5.bin"
cisco WS-C6509-E (R7000) processor (revision 1.5) with 458720K/65536K bytes of memory.
Processor board ID SMG1347N080
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
switchb#
Any feedback would be very appreciated.
Best regard,
GRuiz
Rajat Chauhan
For IOS:
vk1-ac1-6506(config)#logging ?
alarm Configure syslog for alarms
discriminator Create or modify a message discriminator
ip IP configuration
origin-id Add origin ID to syslog messages
transactions
Thank you Rajat,
That´s exactly the point that I just want to confirm.
What should be the minimum IOS version that I require on my WS-C6509-E equipments to support "logging origin-id" command?
Cisco documentation says that this command was introduced in 12.2(15)T, and integrated into 12.2(33)SXH.
My Cisco switches have 12.2(33)SXH5 IOS version.......:(...and they do not support "logging origin-id" (as shown previously).
switchb#sh ver
Any helpful?...It would be very appreciated.
Tks
GRuiz
