long Attributs
alsayed
Level 7
Level 7
HI
When/where we need to made redis with these long Attributs
redistribute ospf 1 match internal external 1 external 2 metric 1 1 1 1 1
many 10xs
shrikar.dange
Level 5
Level 5
the LONG attributes have many things included!!!
1st internal and external matching:
When you use match keword with redistribution you can ask the router to redistribute the internal and external type 1 and type 2 (of ospf in this case)to redistribute in to another routing protocol doamin.
2nd:
The 1 1 1 1 1 metric is used under eigrp for BW Dealay load etc parameters.If you configured the redisribution with these values the metric will be very low.
Under ospf metric can not be 1 1 1 1 1.
It should be only one number the cost.
Such attributes help you to have control over redistribution.
HTH,
regards,
shri 🙂
Jon Marshall
Hi Ali
This is redistributing OSPF routes, both internal and external type 1 and external type 2 into IGRP/EIGRP.
The 1 1 1 1 1 are needed because IGRP/EIGRP use 5 separate values for their metric.
Jon
