Looking for a simple instruction to ping a CATALYST 3560X 24PORT POE IP
Legust321
I was able to access and assugn an IP address to it but I cannot ping it neither access the command prompt to configure it. I will appreciate any help.
Thanks.
Leo Laohoo
I will presume that your switch does not have any config ...
conf t
interface vlan 1
no shutdown
ip address 1.1.1.1 255.255.255.0
exit
int g1/0/1
spanning portfast
switchport access vlan 1
end
Your PC should have an IP address between 1.1.1.2 to 1.1.1.254 with a subnet mask of 255.255.255.0.
Disable any firewall to your PC and try to see if the PC can ping 1.1.1.1 and the switch can ping the IP address to your switch.
Make sure you plug your PC into Gig port 1/0/1 and not the management Fast0 port.
If you connect the PC to the management Fast0 then the configuration will need to change to the following:
conf t
int f0
no shutdown
spanning portf
end
Leo Laohoo
conf t
interface vlan 1
no shutdown
exit
int g1/0/1
spanning portfast
end
conf t
int f0
no shutdown
spanning portf
end
Thanx a lot Leolaohoo, that helped a lot in solving my issue.
  Regards.
Glad to be of assistance.
