LOOKING FOR SOLUTION: CISCO SWITCH12 PORT SFP+ 10G METRO ETHERNET
confreg01
Hi this is my first post so hope it is placed appropriately.
I'm currently looking for 12port SFP+ 10g switch with Metro Ethernet capability.
Struggling to find more than 2 ports on ME switches.
  • Trying to get away from the usual 3600’s due to a lack of 10G ports.
  • Looking for a switch which has only 10G ports, preferably 12+ ports.
  • The 4900’s can be ruled out also since they use X2 SFP’s.
  • Metro Ethernet
Thank you.
Lionel
Joseph W. Doherty
Those not "ME" switches, depending on your feature needs, the 4500-X or the 6840 might be suitable.
9 Replies 9
Julio E. Moisa
Try this tool, it will help you to find the proper device for your requirements.
http://www.cisco.com/c/dam/assets/prod/switches/cisco-switch-selector-how-to/index.html?utm_source=www.uoota.com
Please rate the comment if it is useful.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
Thank you for the link.
It directs me to the WS-C3650 and WS-C3850 range which provides the required 10G SFP+ ports but I am at loss with finding info on Metro Ethernet capability.
Thank you.
Lionel
I dont think the 3650 support 12 SFP ports, but the 3850's they do. I am not really sure if the ME models were replaced by. 6500 or 6800, the following links could be useful:
About the SW 3850 you can find several models:
http://www.cisco.com/c/en/us/products/switches/catalyst-3850-series-switches/models-comparison.html
Switches models:
http://www.cisco.com/c/en/us/products/switches/index.html
Try to find them under Service provider switches - aggregation/ethernet access:
http://www.cisco.com/c/en/us/products/switches/product-listing.html
Hope it is useful
Joseph W. Doherty
Hi Joseph,
Thank you for your reply.
One of the primary requests are for additional 10g ports 12ports or above (12 PORT SFP+ 10G) and then Metro Ethernet.
Would the below provide "ME" ??  Not so well versed with these unfortunately.
source:
http://www.cisco.com/web/partners/downloads/sell/technology/borderless/ge_4500e_series_aag.pdf
WS-C4500X-16SFP+
Catalyst 4500-X 16 Port 10GE IP Base, Front-to-Back Cooling, No P/S
Ports:
16 x 10 Gigabit SFP+
Thank you.
Lionel
Hi Lionel,
Service Provider Switches - Aggregation
Service Provider Switches - Ethernet Access
Again, it depends on your "ME" feature needs.
"ME" switches are often enhanced versions of LAN non-chassis switches.  Their enhancements may include additional or "better" software and/or hardware feature.  For example they may provide more advanced QoS, MPLS support, increase interface buffer capacity, etc.
The 4500 and 6x00 chassis, depending on IOS feature set, usually provide "ME" features too.
So, again, besides your need for 10g ports, you need to identify what "ME" feature you need, if any, and then you can answer your question whether a particular switch will meet your needs.
(BTW, its also possible you don't need "ME" features, and if you don't, then other non-chassis Catalyst switches might also be candidates.)
Thank you for all the comments it certainly assisted in directing me in the right way.
confreg01
Thank you Joseph W. DohertyJulio Moisa
The below was able to meet the requirement.
Appreciate your input and experience and guidance.
Thank you.
Lionel
WS-C4500X-16SFP+
