No Ping ...!!!!!! from Switch
Hi All,
I have an issue with one of my switch ( 4500 series) .
Actual Scenario:
We have a server which has two interfaces and each assigned with an IP address ( in the range[10.49.8.132/27]) . Eth0 IP:10.49.8.135 and Eth1 IP:10.49.8.136 .  Eth0 is connected to Switch-A and Eth-1 is connected to Switch-B . When tried to ping Eth0 IP it is success from switch-A whereas Eth-1 is not a success. Now the same IP's are pingable from the other switch-B . I am not sure what might be wrong . Please advise .
Babjani.
10 Replies 10
Can you please share your configurations. are you using any vlans in this switches
or default you are using ?
thanks
CRaju
Hi Raju ,
Yes , we have vlans on both the switches . Here are the config files attached.
Babjani
I checked the config.. files looks good .
 could you please give a try .
default gateway for your system to use Switch virtual interface  NOT HSRP Virtual ip address
I hope you understand my question . .
this is my mobile number 91+9618613678
CRaju
HI
As I discussed.
If it is possible to try to upgrade your IOS Version to latest .
because both version are different .
cat4500-ipbasek9-mz.150-2.SG5.bin
cat4000-i9k91s-mz.122-25.EWA5.bin
1.https://software.cisco.com/download/release.html?mdfid=279320804&softwareid=280805680&release=12.2.25-EWA&rellifecycle=ED&relind=DEFERRED&reltype=deferred/
2.https://software.cisco.com/download/release.html?mdfid=279636820&softwareid=280805680&release=15.0.2-SG5
CRaju
Thank you Raju , will give it a try .
Julio E. Moisa
Your config looks fine, from what external source are you trying to ping it? is the 2nd NIC on the server configured with a gateway?
If they are on the same subnet they will be able to ping each other without gateway configured on the NICs.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio ,
Yes they are on the same subnet . Eth0 IP:10.49.8.135/27 and Eth1 IP:10.49.8.136/27 as mentioned earlier in the discussion .
Babjani
Thank you, But Im referring if both NICs are configured with the gateway:
10.49.8.134
Hi Julio,
Yes ,both the servers are using the standby IP of HSRP as their gateway. I am pinging it from the switches only and not from any other source .
Hello
These switches seemed to be separate and not stacked or visualized
In a virtual stack link aggregation can span two switches as the server will see it a just one switch, However if the switch isnt "stacked" then the server connections need to be on the same switch in a link aggregation setup.(LACP) which I also don't see in you configuration.
I cannot comment on your server and its teaming software but having a server connected to two separate switches sharing the same address range and default-gateway and without any aggregation setup isnt really feasible.
res
Paul
Kind Regards
Paul
