loop on CISCO ASA 5505
I have a problem with the configuration of my Cisco ASA 5505. I have 2 interfaces 0/2 and 0/3 which are each connected to a switch SW1 and SW2.
On these interfaces I have a trunk multiple VLANs. When I plug the interface 0/2 on the SW1 no problem. But when I add the interface 0/3 on SW2, I have a loop that is.
I made a shema to understand.
the 5505 does not support the spanning tree, the spanning tree is configured on two switches.
Is there a solution to activat the interface 0/3 when 0/2 is down ?
Config of  ASA (0/3 is shutdown to avoid the loop) :
interface Ethernet0 / 2
  switchport trunk allowed vlan 2-4
  switchport mode trunk
interface Ethernet0 / 3
  shutdown
6 Replies 6
cadet alain
you can use the redundant interface feature:
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/intrface.html#wp1045838
Alain
thank you, I'll watch.
I found this command that also seems to solve my problem:
switchport protected (on both interfaces)
Not familiar with the operation of this command. I'll try your method which is more understandable.
switchport protected will prevent interfaces with this feature to communicate, this is also called pvlan edge feature but it will not prevent STP loops to my best knowledge.
Alain
unfortunately I do not have controls available ...
FW-B1#
FW-B1# conf t
FW-B1(config)# int ?
configure mode commands/options:
  Ethernet  IEEE 802.3
  Vlan      Catalyst Vlans
FW-B1(config)# int
you can also try this on the switch side:
http://www.the-lan-man.net/wordpress/2010/asa-5505-switch-redundancy/
Alain
thank you for your help Alain,
unfortunately i don't have a 3750 stack behind but I have only 2 DELL 3524 without stack.
there is just a port-channel between swtichs.
I'll keep looking, but my case seems to have no solution
thank you again
