Loopback Problems
I am try to setup a couple of Loopback address on my Cisco 2851 Router....
Here are parts of my config file:
interface GigabitEthernet0/0
 description  INSIDE
 ip address 192.168.0.50 255.255.255.0
 ip access-group 100 in
 no ip redirects
 no ip unreachables
 ip proxy-arp
 ip nbar protocol-discovery
 ip flow ingress
 ip flow egress
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no cdp enable
 no mop enabled
access-list 1 remark INSIDE_IF=GigabitEthernet0/0
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 100 remark *** GigabitEthernet0/0 SCORPNET ***
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
So I was trying to create Loopback address:
interface Loopback0
 ip address 192.168.0.20 255.255.255.0
interface Loopback1
 ip address 192.168.0.21 255.255.255.0
interface Loopback2
 ip address 192.168.0.22 255.255.255.0
interface Loopback3
 ip address 192.168.0.23 255.255.255.0
I get an error that 192.168.0.0 overlapping with each of the loopback address....
Can someone let me know what I may be doing wrong...
Thanks.......
3 Accepted Solutions
Jon Marshall
You cannot use the same IP subnet on multiple different interfaces which is what the router is telling you.
Each interface needs to use a different subnet.
Jon
Hello
@DAVID RICHWALSKI wrote:
so that is why I am getting the message:
% 192.168.0.0 overlaps with Loopback0
% 192.168.0.0 overlaps with Loopback0%Default route without gateway, if not a point-to-point interface, may impact performance
SETUP: new interface GigabitEthernet0/0 placed in "shutdown" state
So if I understand right I cannot have ANY loopback on the 255.255.255.0 subnet correct?
No that inst correct - you CAN but as stated by Jon/Philip you cannot have the same subnet on multiple interfaces be it loopbacks or any other interface.
192.168.0.20
255.255.255.0
192.168.0.21
255.255.255.0
192.168.0.22
255.255.255.0
etc...
All the above are in the same subnet,
what will work is
192.168.0.20
255.255.255.0
192.168.1.20
255.255.255.0
192.168.2.21
255.255.255.0
etc..
or as stated by philip
192.168.0.20
255.255.255.255
192.168.0.21
255.255.255.255
192.168.0.22
255.255.255.255
res
Paul
Kind Regards
Paul
Hi paul.......I just dont understand why it will not work I followed your directions
I added ip subnet-zero to my startup-config
I tried both :
192.168.0.20
255.255.255.255
192.168.0.20
255.255.255.0
I still get the overlap error
14 Replies 14
Jon Marshall
Jon
Hello
192.168.0.20
255.255.255.0
192.168.0.21
255.255.255.0
192.168.0.22
255.255.255.0
etc...
what will work is
192.168.0.20
255.255.255.0
192.168.1.20
255.255.255.0
192.168.2.21
255.255.255.0
etc..
192.168.0.20
255.255.255.255
192.168.0.21
255.255.255.255
192.168.0.22
255.255.255.255
res
Paul
Kind Regards
Paul
I am extremely thankful for the help but I tried bot suggestions and i still cannot get it to work..so I have included my config file for you to look at I you may:
! Last configuration change at 20:37:56 CST Sun Jan 21 2018
! NVRAM config last updated at 20:40:29 CST Sun Jan 21 2018 by scorpion
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec show-timezone
service password-encryption
service sequence-numbers
hostname ***********
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging count
no logging buffered
no logging rate-limit
enable secret 5 **************
enable password 7 *******************
no aaa new-model
no process cpu extended history
no process cpu autoprofile hog
clock timezone CST -6 0
clock summer-time CDT recurring
dot11 syslog
ip source-route
no ip gratuitous-arps
ip cef
no ip bootp server
ip domain name ************
ip host ******************
ip name-server ***************
ip inspect name protocol dns
ip inspect name protocol ftp
ip inspect name protocol https
ip inspect name protocol icmp
ip inspect name protocol tcp
ip inspect name protocol udp
no ipv6 cef
voice-card 0
license udi pid CISCO2851 sn ************
username ******** privilege 15 secret 5 **************
redundancy
ip tcp synwait-time 10
ip ssh authentication-retries 5
ip ssh port ****** rotary 1
ip ssh rsa keypair-name *******
ip ssh logging events
ip ssh version 2
ip ssh dh min size 4096
buffers tune automatic
 description INSIDE
 no ip redirects
 no ip unreachables
 ip proxy-arp
 ip flow ingress
 ip flow egress
 ip nat inside
 duplex auto
 speed auto
 no cdp enable
 no mop enabled
interface GigabitEthernet0/1
 description PrimaryWANDesc_SPECTRUM$FW_OUTSIDE$$ETH-WAN$
  mac-address *************
 ip address dhcp client-id GigabitEthernet0/1
 ip address dhcp hostname ***********
 ip access-group 101 in
 ip mask-reply
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip flow egress
 ip nat outside
 ip inspect protocol out
 duplex auto
 speed auto
 ntp disable
 no cdp enable
 no mop enabled
interface ATM0/0/0
 no ip address
 shutdown
 no atm ilmi-keepalive
ip forward-protocol nd
ip http server
ip http access-class 2
ip http authentication local
no ip http secure-server
ip flow-export version 5
ip flow-export destination
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip access-list extended DenyStdSSH
 deny   tcp any any eq 22
 permit tcp any any eq
logging trap debugging
logging source-interface GigabitEthernet0/0
logging *********
access-list 100 remark *** GigabitEthernet0/0 ***
access-list 100 remark *******************************
access-list 101 remark *** GigabitEthernet0/1 SPECTRUM ***
access-list 101 remark --- SPECTRUM DHCP ---
access-list 101 permit udp any eq bootps any eq bootpc log
access-list 101 remark *******************************
access-list 101 remark --- DNS ---
access-list 101 permit udp any eq domain any
access-list 101 permit tcp any eq domain any
access-list 101 remark --- SSH ALTERNATE PORT ---
access-list 101 permit tcp any any eq
access-list 101 remark --- DNSCRYPT ---
access-list 101 permit udp any any eq
access-list 101 remark --- PLEX MEDIA SERVER ---
access-list 101 remark --- FTPS Explicit (Passive) ---
access-list 101 remark --- SFTP (SSH) ---
access-list 101 remark --- SOFTETHER VPN ---
access-list 101 remark --- DAMEWARE ---
access-list 101 remark --- XBOX LIVE ---
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any any eq 3074
access-list 101 permit udp any any eq 88
access-list 101 permit udp any any eq isakmp
access-list 101 permit udp any any eq 3074
access-list 101 permit udp any any eq 3544
access-list 101 permit udp any any eq non500-isakmp
access-list 101 remark --- ICMP ---
access-list 101 permit icmp any any parameter-problem
access-list 101 permit icmp any any net-unreachable
access-list 101 permit icmp any any host-unreachable
access-list 101 permit icmp any any port-unreachable
access-list 101 permit icmp any any packet-too-big
access-list 101 permit icmp any any administratively-prohibited
access-list 101 permit icmp any any ttl-exceeded
access-list 101 permit icmp any any echo-reply
access-list 101 deny   icmp any any log
access-list 101 deny   ip 10.0.0.0 0.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 deny   ip 172.16.0.0 0.15.255.255 any
access-list 101 deny   ip 192.168.0.0 0.0.255.255 any
access-list 101 deny   ip 224.0.0.0 31.255.255.255 any
access-list 101 deny   ip host 0.0.0.0 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip any any log
no cdp run
control-plane
mgcp profile default
line con 0
 exec-timeout 60 0
 login local
 transport preferred none
 transport output telnet
line aux 0
 exec-timeout 0 1
 no exec
line vty 0 4
 access-class DenyStdSSH in
 exec-timeout 20 0
 privilege level 15
 login local
 rotary 1
 transport preferred ssh
 transport input ssh
 transport output ssh
scheduler allocate 20000 1000
ntp logging
ntp update-calendar
ntp server 192.168.0.15 prefer source GigabitEthernet0/0
end
Hello
what exactly are you trying to do ?
Jus create loopbacks correct?
res
paul
Kind Regards
Paul
yes just create 3 loopback .....
Philip D'Ath
Meraki Community All-Star
Change your loopback subnet masks to 255.255.255.255.  They should also be in a different subnet than Gigabit0/0.
Well since I only have that single subnet I guess I won't be able to get it to work......
Thanks fo the help
As others also noted, here is how you can create 3 loopbacks with 3 different IPs,
see example:
interface Loopback0
ip address 192.168.0.20 255.255.255.255
interface Loopback1
ip address 192.168.0.21 255.255.255.255
interface Loopback2
ip address 192.168.0.22 255.255.255.255
Hello I did that exactly and still get the overlap error
Conf t
Ip subnet-zero
Kind Regards
Paul
I tried both :
192.168.0.20
255.255.255.255
192.168.0.20
255.255.255.0
You have used 192.168.0.0/24 on gi0/0 which means your loopbacks cannot use any IP from that subnet.
It is that simple.
Jon
I am VERY thankful for EVERYONES help...I FINALLY got it....I had to get my head wrapped adound this.....Paul suggestion of 192.168.1.20 255.255.255.0 it worked...I just did not see it...thank you all for your help
