Lost
jlcarey1usa
Strange situation. Have a company with two physical sites connected via a point-to-point T1. On each end of the T1 are old Cisco 1602R routers. The problem is actually with Exchange servers failing to talk to each other properly. Site A is main office and Site B is branch office. Each site contains 1 Exchange server and the sites are supposed to talk over this p-t-p connection. I cannot use telnet to connect from site A to site B over port 25. I can however, connect from site B to site A over port 25.
Essentially, the communication between these Exchange servers is failing because messages cannot go from site A to site B, but can go from site B to site A.
The interesting thing is that I can use telnet from site A to site B using a different port, say 691 which is also used with Exchange and it works fine.
I can telnet into site B router and establish a telnet session to the Exchange server in site B.
The problem is router A. For some reason, it will not allow requests over port 25 to go through.
Any clue???
84 Replies 84
James
In general cut and paste works well in transferring configuration information from one router to another router. You do sometime need to watch out for changes in interface numbering which might change between models of router. I am not clear whether this is an issue here.
I am not sure what static route you are talking about adding. It almost sounds like you are planning for a static route for the subnet of the interface. You do not need to do this. The connected interface subnet will show up in the local routing table automatically. If it is some other static route then please clarify what static route it is.
Rick
Rick
I see what you are saying. I will need to be careful about the interface numbers. I think I actually have them backwards. It doesn't matter though. So, the local routing table will automatically understand that all requests to the Internet, (i.e. not to the other subnet) will need to go out the new interface. I thought you actually had to add a route in the config that would let the router know that.
James
Each router currently has a static default route (and the GA router has an additional floating static default route). when you connect the firewall on another interface and change the IP address of the firewall you will need to change the existing static default route. Your post talked about adding a static route, perhaps you meant change the static route.
Rick
Rick
Rick,
We are starting to configure the new routers. So far this is what we have:
From my pc, I am unable to ping 192.168.0.1 or 192.168.0.2 which is the connection between the router and the Sonicwall firewall. 110.0 is the subnet I am on.
NY2811>en
Password:
NY2811#sh run
Building configuration...
Current configuration : 1081 bytes
version 12.3
hostname NY2811
boot-start-marker
boot-end-marker
enable secret 5 $1$SazW$RKdLN.XMp2gL9DmJFl2kC1
enable password stanton
no aaa new-model
ip subnet-zero
no ip routing
no ip cef
ip ips po max-events 100
no ftp-server write-enable
interface FastEthernet0/0
ip address 192.168.110.1 255.255.255.0
no ip route-cache
duplex full
speed auto
no mop enabled
interface FastEthernet0/1
ip address 192.168.0.1 255.255.0.0
no ip route-cache
duplex auto
speed auto
interface Serial0/0/0
bandwidth 1120
ip address 10.1.2.1 255.255.255.0
no ip route-cache
no fair-queue
interface Serial0/1/0
no ip address
no ip route-cache
shutdown
clockrate 2000000
no ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.2
ip route 192.168.120.0 255.255.255.0 10.1.2.2
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
password carpet
login
scheduler allocate 20000 1000
end
NY2811#
James
I am not sure why this is in the config:
no ip routing
I would suggest that you configure:
ip routing
and see what happens.
Rick
Rick
Yes, we missed some configuration info. The only thing that seems to be not functioning is the actual p-t-p connection. We are unable to set the clocking on it. This is a 2811 router. We used the service-module t1 clock source line/internal command and it did not take.
Perhaps there is some new command for this newer router?
James
What kind of card is the T1 in the 2811?
I am curious about what part of it did not work? Did it not accept the service-module t1 command? Or did it accept the service-module command but not the clock source command?
And how do you know that it did not take? Especially if you set it to clock source line that is the default and probably would not show up in the config. If you set it to clock source internal I would expect that to show up in the config.
Could you post the output of show service-module?
Rick
Rick
Rick,
I will post the sh run and sh int from both routers. The NY one is a 2811 and the GA one is still a 1600, but we will be replacing it with a 2611.
GEORGIA
User Access Verification
Password:
GA_router>en
Password:
GA_router#sh run
Current configuration:
version 11.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service udp-small-servers
no service tcp-small-servers
hostname GA_router
enable password 7 104D000A0618
ip subnet-zero
no ip domain-lookup
interface Ethernet0
description connected to GA_LAN
ip address 192.168.120.1 255.255.255.0
no ip directed-broadcast
interface Serial0
description 56k csu/dsu NOT USED
no ip address
encapsulation ppp
shutdown
service-module 56k clock source internal
service-module 56k network-type dds
interface Serial1
description connected to NY via t1
ip address 10.1.2.2 255.255.255.0
encapsulation ppp
bandwidth 1120
service-module t1 clock source internal
service-module t1 timeslots 1-20
service-module t1 remote-alarm-enable
no ip classless
ip route 0.0.0.0 0.0.0.0 192.168.120.2
ip route 192.168.110.0 255.255.255.0 10.1.2.1
line con 0
exec-timeout 0 0
password 7 030752180500
login
transport input none
line vty 0 4
password 7 01100F175804
login
end
GA_router#
NEW YORK
NY2811#sh run
Current configuration : 1078 bytes
version 12.3
hostname NY2811
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
duplex full
speed auto
no mop enabled
no ip address
shutdown
duplex auto
speed auto
encapsulation ppp
no fair-queue
no ip address
shutdown
clockrate 2000000
router rip
network 10.0.0.0
network 192.168.0.0
network 192.168.110.0
network 192.168.120.0
no ip classless
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password carpet
login
end
NY2811# ~
NEW YORK
NY2811#sh int s0/0/0
Serial0/0/0 is up, line protocol is down
Hardware is GT96K with integrated T1 CSU/DSU
Internet address is 10.1.2.1/24
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 128/255, txload 1/255, rxload 1/255
Encapsulation PPP, LCP Listen, loopback not set
Keepalive set (10 sec)
Last input 00:00:20, output 00:00:14, output hang never
Last clearing of "show interface" counters 02:07:02
Queueing strategy: fifo
Output queue: 0/40 (size/max)
55 packets input, 770 bytes, 0 no buffer
Received 0 broadcasts, 2 runts, 0 giants, 0 throttles
2270 input errors, 2248 CRC, 111 frame, 73 overrun, 0 ignored, 2171 abort
1691 packets output, 23564 bytes, 0 underruns
0 output errors, 0 collisions, 411 interface resets
2 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
NY2811#
GEORGIA
GA_router#sh int s1
Serial1 is up, line protocol is down
Hardware is QUICC Serial (with FT1 CSU/DSU WIC)
Description: connected to NY via t1
Internet address is 10.1.2.2/24
MTU 1500 bytes, BW 1120 Kbit, DLY 20000 usec, rely 182/255, load 1/255
Encapsulation PPP, loopback not set, keepalive set (10 sec)
LCP ACKsent
Closed: IPCP, CDPCP
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
161 packets input, 2174 bytes, 0 no buffer
Received 161 broadcasts, 0 runts, 0 giants, 0 throttles
717 input errors, 379 CRC, 323 frame, 0 overrun, 0 ignored, 15 abort
1190 packets output, 23810 bytes, 0 underruns
0 output errors, 0 collisions, 107 interface resets
1 carrier transitions
GA_router#
James
I believe that the immediate problem is that the GA router knows that the connection is a partial T1:
but it looks like the NY router believes that it is a full T1. We need to get this resolved to see if there are any other issues.
What kind of card is in the NY router? If I knew that we might find what it takes to configure it properly.
Rick
Rick
James
I do not see it in the config that you posted from the NY router and I wonder if you need the command:
card type t1
This should then enable the controller t1 command to set the timeslots.
Rick
Rick
Rick,
I haven't been able to look at the router yet, but I will see about that command.
Rick,
We ran into some problems, so we decided to blow out the config and start again. We want to load the factory defaults, but when we do it, we get some errors. Specifically,
%error opening tftp://255.255.255.255/network-config (Timed Out)
when we tried to do it again, one of the eth interfaces comes up with a dhcp address. Obviously we should get a blank config.
James
There is a feature in IOS for auto config and if an IOS router boots with an empty config and if its interfaces are connected to something that has an IP address that the router can identify, then the router will generate an IP address in that subnet. If you disconnect all the interfaces before you boot the router that should not happen again.
Also the error about %error opening tftp://255.255.255.255/network-config (Timed Out) is from a line in the config that says:
service config
it may have gotten into the config as part of the auto config. If it is in the config and you remove it, there should not be any more of these errors.
Rick
Rick
Rick
We were able to get around it. We reconfigured all of the interfaces and we are starting over. I will get back to you with a more meaningful question. Thanks for your patience.
