Low Memory Catalyst WS-C2960S-48FPS-L - 15.0(2)SE3
Erico Verissimo
Hello all,
Have someone experienced low memory on this device? My switch was working and after some days I tried to access it by ssh, it didn't response, by console there was the message "low on memory.. try later". However, after reset, it became work well but the memory is filling along the days and now it is 61% used.
sw1#sh version
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.0(2)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 24-May-13 05:52 by prod_rel_team
ROM: Bootstrap program is C2960S board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE, RELEASE SOFTWARE (fc3)
SPZFLR_DC6_INT1 uptime is 10 hours, 20 minutes
System restarted at 22:27:20 BR Tue Mar 29 2011
System image file is "flash:/c2960s-universalk9-mz.150-2.SE3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-48FPS-L (PowerPC) processor (revision B0) with 131072K bytes of memory.
Processor board ID FOC1446Z7AU
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : F0:25:72:69:70:00
Motherboard assembly number : 73-12547-06
Power supply part number : 341-0382-02
Motherboard serial number : FOC14471K74
Power supply serial number : LIT14410B9A
Model revision number : B0
Motherboard revision number : A0
Model number : WS-C2960S-48FPS-L
Daughterboard assembly number : 73-11933-04
Daughterboard serial number : FOC1447139P
System serial number : FOC1446Z7AU
Top Assembly Part Number : 800-32647-02
Top Assembly Revision Number : A0
Version ID : V02
CLEI Code Number : COMGB00ARB
Daughterboard revision number : A0
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 52 WS-C2960S-48FPS-L 15.0(2)SE3 C2960S-UNIVERSALK9-M
sw1#sh processes memory sorted
Processor Pool Total: 66584056 Used: 38639584 Free: 27944472
I/O Pool Total: 14680064 Used: 12386332 Free: 2293732
Driver te Pool Total: 1048576 Used: 40 Free: 1048536
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 71181408 25749080 41743108 0 0 *Init*
0 0 71000404 54433888 1987164 12423527 928178 *Dead*
90 0 731392 144048 468780 0 0 Stack Mgr Notifi
184 0 392100 9624 395412 0 0 Auth Manager
0 0 0 0 394440 0 0 *MallocLite*
61 0 368228 600 377788 0 0 EEM ED Identity
178 0 298568 3860 294832 0 0 HL2MCM
177 0 295824 1260 294744 0 0 HL2MCM
325 0 265100 0 275260 100548 0 EEM ED Syslog
1 0 192656 52840 146976 0 0 Chunk Manager
303 0 110680 416 123424 0 0 Crypto IKEv2
336 0 107404 0 114564 0 0 EEM Server
109 0 92632 0 99792 53760 0 HRPC emac reques
135 1 3611572 3528748 94812 0 0 SSH Process
Thanks for any help!
Érico
Mark Malone
If your constantly getting low memory change the IOS version , that's an early deployment ios move to the recommended version safe harbour c2960s-universalk9-mz.150-2a.SE9.bin  or to any other MD release. Some ios versions can be more susceptible to mem leaks than others
Mark Malone
Thanks so much!
