Bookmark
Subscribe
3064
Low Memory on router
kechy4001
Hello All,
I am in a fix here. Just got to work and found most users cannot connect to the internet and on checking the router via Telnet it threw me pout with the error message connection failed . Port 23 cannot be accessed. I logged in via console and then got the low memory.
Users can hardly work and I want to get this fixed and everything seems not to work again.
I will appreciate any assistance to get out of this since there is no backup router to use at this time.
Thank you
Kechy4001.
7 Replies 7
Collect a "show proc mem sorted" and reload it to free the stuck memory.
Thanks Norbert . Please the show "proc Mem sorted' is it a command I need to run on the router and then reload by typing reload ???.
I saw an article someone commented that we should use the default command below
config t
no ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
ip route 0.0.0.0 0.0.0.0 1.1.1.2
end
Is it also correct to run this on my production router ? or just follow the instruction you have stated in your response
We need to investigate what is eating the memory. You can check what Joseph suggested.
You can run the commands "show proc mem sorted", "show arp", "show run" in the router grab the outputs and attach here. We will take a look before reloading it.
please see report from show proc mem sorted. please router is cisco router 1800 series with 64MB flash on it.
GTBAsset#show proc mem sorted
*Jun  2 08:50:33.983: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for ipnat node. No memory available -Process= "Chunk Manager", ipl= 4, pid= 1 -Traceback= 0x808FEC68 0x80375778 0x800C8384 0x800CBAD8
Processor Pool Total:   71999524 Used:   71914688 Free:      84836
      I/O Pool Total:   12582912 Used:   12579416 Free:       3496
 PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   1   0   55157144     266500   54964312          0          0 Chunk Manager
   0   0   50566980   23208504   23614932          0          0 *Init*
  68   0   13957732       2272    2718244          0          0 IP Input
 157   0     395144      12920     394936          0          0 IPSEC key engine
  18   0     261628          0     271704     113400          0 EEM ED Syslog
   0   0     189668    2109880     139600     655736          0 *Dead*
   5   0   43226924   43100696     133304      31644          0 Pool Manager
  94   0     103564        156     110640          0          0 L2MM
 151   0      67340       3700      89080          0          0 Crypto ACL
 156   0      66852          0      79928          0          0 Crypto IKEv2
  93   0      73404          0      73404          0          0 CEF process
 129   0      65660        252      72484          0          0 HTTP Process
  97   0      38464        252      37136          0          0 DHCPD Receive
 146   0        284          0      25360          0          0 RPMS_PROC_MAIN
 192   0        252          0      25328          0          0 tHUB
 104   0          0          0      25076          0          0 COPS
   8   0          0          0      25076          0          0 Crash writer
 116   0      16844        252      23668          0          0 SCTP Main Proces
  91   0      22172      10128      22120          0          0 IP Background
 --More--
*Jun  2 08:50:37.383: %SYS-2-MALLOCFAIL: Memory allocation of 65536 bytes failed from 0x80376A00, alignment 8
Pool: Processor  Free: 77984  Cause: Memory fragmentation
Alternate Pool: I/O  Free: 3496  Cause: Not enough free memory
 -Process= "IP Input", ipl= 0, pid= 68 -Traceback= 0x808FEC68 0x80350FEC 0x80356E28 0x80376A04 0x80375A98 0x803783E0 0x803758E8 0x80E2E104 0x80E2F924 0x80E30500 0x80E3289C 0x80E2D764 0x80CCA324 0x80CC8828 0x80CC8B44   28   0       8368        664      20844          0          0 Exec
 131   0      12592        252      19416          0          0 CIFS Proxy Proce
 184   0      10012        252      19176          0          0 EEM Policy Direc
 200   0      14624          0      18664          0          0 RIP Router
 155   0       4824        252      17648          0          0 Crypto IKMP
 178   0      13408       3684      17460          0          0 EEM Server
 197   0      10268        252      17092       2080          0 VRRP
 107   0       5992          0      16068          0          0 HTTP CORE
  31   0      22360          0      14208          0          0 Net Background
 182   0      76540      69812      13648          0          0 VLAN Manager
  32   0       3784       3528      13332          0          0 IDB Work
 193   0        504        252      13328          0          0 tENM
 112   0        252        252      13076          0          0 X.25 Background
 125   0          0          0      13076          0          0 XSM_ENQUEUER
  15   0          0          0      13076          0          0 Policy Manager
  25   0        252        252      13076          0          0 Dialer event
  33   0        252        252      13076          0          0 Logger
 103   0          0       9548      13076          0          0 TCP Protocols
 102   0          0          0      13076          0          0 TCP Timer
 --More--
*Jun  2 08:50:43.987: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for ipnat node. No memory available -Process= "Chunk Manager", ipl= 4, pid= 1 -Traceback= 0x808FEC68 0x80375778 0x800C8384  154   0        252        492      13076          0          0 Crypto IKE Dispa
 126   0          0          0      13076          0          0 XSM Historian
  27   0        252        252      13076          0          0 XML Proxy Client
  81   0        252        252      13076          0          0 L2TP mgmt daemon
  86   0        252        252      13076          0          0 PPP IP Route
  85   0        252        252      13076          0          0 KRB5 AAA
  72   0        504        504      13076          0          0 PPP Hooks
  75   0          0          0      13076          0          0 SSS Test Client
 185   0     127540     127540      13076          0          0 Syslog
  87   0        252        252      13076          0          0 PPP IPCP
  74   0          0          0      13076          0          0 SSS Manager
  78   0          0          0      13076          0          0 VPDN call manage
  80   0          0          0      13076          0          0 L2X SSS manager
  79   0          0          0      13076          0          0 L2X Socket proce
 188   0       5304        252      12128          0          0 Compute load avg
   0   0      12128     195512      12128          0          0 *Sched*
  11   0       4248          0      11324        780          0 ARP Input
  40   0      13176        956      11188          0          0 ESWPPM
  67   0       3764        412      10588          0          0 CDP Protocol
  17   0       3244          0      10320          0          0 Entity MIB API
   4   0       3372        252      10256          0          0 Check heaps
  92   0        164          0      10240          0          0 IP RIB Update
 174   0         76          0      10152          0          0 EEM ED Resource
  61   0        252        252      10076          0          0 Dot11 auth Dot1x
 177   0          0          0      10076          0          0 EEM ED Track
 176   0          0          0      10076          0          0 EEM ED Timer
 175   0          0          0      10076          0          0 EEM ED SNMP
  60   0        252        252      10076          0          0 Dot11 aaa proces
 173   0          0          0      10076          0          0 EEM ED OIR
 172   0          0          0      10076          0          0 EEM ED None
 171   0          0          0      10076          0          0 EEM ED Memory-th
 170   0          0          0      10076          0          0 EEM ED IOSWD
 169   0          0          0      10076          0          0 EEM ED Interface
 168   0          0          0      10076          0          0 EEM ED Counter
 167   0          0          0      10076          0          0 EEM ED CLI
  46   0          0          0      10076          0          0 Crypto Device Up
  83   0        252        252      10076          0          0 EAPoUDP Process
 106   0        252        252      10076          0          0 Adj Manager
  35   0          0          0      10076          0          0 Per-Second Jobs
 147   0       1428        652       9852          0          0 Crypto CA
  53   0       2500        252       9324          0          0 DTP Protocol
 143   0        416        252       9240          0          0 Crypto WUI
 148   0          0          0       9076          0          0 Crypto PKI-CRL
 149   0          0          0       9076          0          0 Crypto SSL
 160   0          0          0       9076          0          0 Key Proc
 191   0      36888      37256       9076          0          0 crypto sw pk pro
 132   0       1192        252       8016          0          0 URL filter proc
 141   0       1068        252       7892          0          0 TPLUS
 127   0       1020        252       7844          0          0 SSLVPN_PROCESS
  49   0      11556       1772       7416          0          0 crypto engine pr
 183   0        220          0       7296          0          0 DHCPD Database
  89   0        468        252       7292          0          0 Dot1x Supplicant
 122   0        424        252       7248          0          0 SDEE Management
  90   0        416        252       7240          0          0 Dot1x Supplicant
 190   0        164          0       7240          0          0 CEF Scanner
  88   0        416        252       7240          0          0 Dot1x Supplicant
 164   0        164          0       7240          0          0 DATA Transfer Pr
   3   0        164          0       7240          0          0 Spanning Tree
 165   0        164          0       7240          0          0 DATA Collector
  34   0     168988        252       7180          0          0 TTY Background
  99   0          0          0       7076          0          0 Socket Timers
  98   0          0          0       7076          0          0 IP Traceroute
  37   0          0          0       7076          0          0 Token Daemon
  47   0          0          0       7076          0          0 Multi-ISA Event
 100   0        252        252       7076          0          0 RLM groups Proce
  36   0          0          0       7076          0          0 AggMgr Process
 105   0        252        252       7076          0          0 Dialer Forwarder
  30   0          0          0       7076          0          0 Critical Bkgnd
  26   0          0          0       7076          0          0 SERIAL A'detect
 108   0          0   11174152       7076          0          0 IP Cache Ager
 109   0          0          0       7076          0          0 RARP Input
 110   0          0          0       7076          0          0 Transport Port A
 111   0          0          0       7076          0          0 PAD InCall
  96   0          0
*Jun  2 08:50:53.987: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for ipnat node. No memory available -Process= "Chunk Manager", ipl= 4, pid= 1 -Traceback= 0x808FEC68 0x80375778 0x800C8384 0x800CBAD8    0       7076          0          0 IGMPSN
 113   0        252        252       7076          0          0 PPP Bind
 114   0        252        252       7076          0          0 PPP SSS
 115   0        252        252       7076          0          0 RBSCP Background
  48   0          0          0       7076          0          0 Multi-ISA Cleanu
  24   0        252        252       7076          0          0 GraphIt
 118   0          0          0       7076          0          0 DHCPD Timer
 119   0          0          0       7076          0          0 Authentication P
 120   0          0          0       7076          0          0 Auth-proxy AAA B
 121   0          0          0       7076          0          0 IPS Timer
  84   0          0          0       7076          0          0 IPv6 RIB Redistr
 123   0          0          0       7076          0          0 IPv6 Inspect Tim
 124   0          0          0       7076          0          0 XSM_EVENT_ENGINE
  21   0          0          0       7076          0          0 RO Notify Timers
  20   0        252        252       7076          0          0 Serial Backgroun
  82   0          0          0       7076          0          0 X.25 Encaps Mana
 128   0          0          0       7076          0          0 Select Timers
  23   0        252        252       7076          0          0 SMART
 130   0        252        252       7076          0          0 CIFS API Process
  16   0        252        252       7076          0          0 DDR Timers
  50   0        704        704       7076          0          0 Switch Link Moni
 133   0        504        504       7076          0          0 Crypto HW Proc
 135   0        252        252       7076          0          0 AAA Cached Serve
 136   0        252        252       7076          0          0 ENABLE AAA
  43   0          0          0       7076          0          0 Platform Compact
 117   0        252        252       7076          0          0 Inspect process
  95   0          0          0       7076          0          0 MRD
 140   0        252        252       7076          0          0 LOCAL AAA
  51   0        252        252       7076          0          0 COLLECT STAT COU
 142   0        252        252       7076          0          0 VSP_MGR
  52   0        252        252       7076          0          0 PI MATM Aging Pr
 144   0        252        252       7076          0          0 Crypto Support
 145   0          0          0       7076          0          0 EPM MAIN PROCESS
  14   0          0          0       7076          0          0 AAA_SERVER_DEADT
  77   0          0          0       7076          0          0 SSS Feature Time
  76   0          0          0       7076          0          0 SSS Feature Mana
  54   0        252        252       7076          0          0 dot1x
 150   0          0          0       7076          0          0 encrypt proc
  13   0        252        252       7076          0          0 AAA high-capacit
 152   0          0          0       7076          0          0 CRYPTO QoS proce
 153   0          0          0       7076          0          0 Crypto INT
  12   0        252        252       7076          0          0 ATM Idle Timer
  10   0          0          0       7076          0          0 Fan Fault Deboun
   9   0          0          0       7076          0          0 Over Heat Deboun
   7   0        252        252       7076          0          0 LED Timers
 158   0          0          0       7076          0          0 IPSEC manual key
 159   0          0          0       7076          0          0 Crypto PAS Proc
  55   0        252        252       7076          0          0 Dot1x Mgr Proces
 161   0          0          0       7076          0          0 GDOI GM Process
 162   0          0       1032       7076          0          0 PM Callback
 163   0        252        252       7076          0          0 Control-plane ho
  19   0          0          0       7076          0          0 HC Counter Timer
 138   0          0          0       7076          0          0 Key chain liveke
 166   0        252        252       7076          0          0 AAA SEND STOP EV
  56   0          0          0       7076          0          0 EAP Framework
  71   0        252        252       7076          0          0 TurboACL chunk
  70   0        252        252       7076          0          0 TurboACL
  69   0          0          0       7076          0          0 ICMP event handl
  57   0          0          0       7076          0          0 linktest
  58   0        252        252       7076          0          0 Dot11 Mgmt & Ass
  66   0          0          0       7076          0          0 ACCT Periodic Pr
  65   0          0          0       7076          0          0 AAA ACCT Proc
  64   0        252        252       7076          0          0 AAA Server
  63   0        252        252       7076          0          0 AAA Dictionary R
  62   0          0          0       7076          0          0 Dot11 Mac Auth
   6   0        252        252       7076          0          0 Timers
 179   0        252        252       7076          0          0 RMON Recycle Pro
 180   0        252        252       7076          0          0 RMON Deferred Se
 181   0          0          0       7076          0          0 Syslog Traps
 139   0        252        252       7076          0          0 LINE AAA
 137   0          0          0       7076          0          0 EM Background Pr
 101   0          0          0       7076          0          0 SNMP Timers
 202   0      82756       3728       7076          0          0 RIP Timers
 186   0          0          0       7076          0
 187   0          0          0       7076          0          0 Net Input
 194   0        252        252       7076          0          0 IP NAT Ager
 189   0          0          0       7076          0          0 Per-minute Jobs
 195   0          0          0       7076          0          0 IP NAT WLAN
 196   0          0          0       7076          0          0 IP VFR proc
 201   0          0      79028       7076          0          0 RIP Send
 198   0        252        252       7076          0          0 HSRP Common
  45   0          0          0       4076          0          0 IGMP Snooping Re
  44   0          0          0       4076          0          0 IGMP Snooping Pr
  41   0        252        252       4076          0          0 Eswilp Storm Con
  22   0          0          0       4076          0          0 RMI RM Notify Wa
  38   0          0          0       4076          0          0 dev_device_inser
   2   0        252        252       4076          0          0 Load Meter
  39   0          0          0       4076          0          0 dev_device_remov
  29   0          0          0       4076          0          0 Inode Table Dest
                                 84447448 Total
Result from arp
GTBAsset#show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.75.1.100             -   001e.f7d4.a33a  ARPA   Vlan1
Internet  10.35.202.162           -   001e.f7d4.a33a  ARPA   FastEthernet0
Internet  10.35.202.161          34   5057.a8c7.4a03  ARPA   FastEthernet0
Internet  10.75.10.3             34   001f.caf0.0b21  ARPA   Vlan2
Internet  10.75.10.2              -   001e.f7d4.a33a  ARPA   Vlan2
Internet  10.75.10.1              -   0000.5e00.0101  ARPA   Vlan2
Internet  10.10.245.105           -   001e.f7d4.a33a  ARPA   Vlan20
Internet  10.10.200.1             -   001e.f7d4.a33a  ARPA   Vlan350
Internet  10.132.0.94            34   503d.e5af.8c00  ARPA   Vlan30
Internet  10.132.0.95             -   001e.f7d4.a33a  ARPA   Vlan30
Internet  80.248.9.81             1   000f.3588.1bfc  ARPA   FastEthernet1
Internet  80.248.9.85             -   001e.f7d4.a33b  ARPA   FastEthernet1
Internet  80.248.9.87             -   001e.f7d4.a33b  ARPA   FastEthernet1
Internet  80.248.9.89             -   001e.f7d4.a33b  ARPA   FastEthernet1
Internet  80.248.9.88             -   001e.f7d4.a33b  ARPA   FastEthernet1
Internet  80.248.9.91             -   001e.f7d4.a33b  ARPA   FastEthernet1
Internet  80.248.9.90             -   001e.f7d4.a33b  ARPA   FastEthernet1
Internet  80.248.9.92             -   001e.f7d4.a33b  ARPA   FastEthernet1
Internet  80.248.9.94             -   001e.f7d4.a33b  ARPA   FastEthernet1
Please edit your post and remove the public IPs, from the show arp table.
If you reload it the issue appears again immediately or take some time to reappear?
Can you send show ip nat statistics?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
A common issue, when routing to the internet, is using a default route to the interface rather than a default route to the next hop (on that interface).  The former will "eat" memory from its ARP table, the latter will not.  Something you might want to check.
