low memory
aalvarez150210
good day, I have a problem catalyst 3560 since he himself after several days, it sends a message to me of which it has low memory, does not allow me to access VTY way and no Console way, after some hour does not respond echo to me ICMP and by ultimi it lets comutar and the communication is affected,
this problem is due to I deal corupt in my network? or it is a problem of makes of these equipment?
5 Replies 5
Amit Singh
What is the IOS version you are running on the switch. Please paste " show version" and " show run" from the switch.
-amit singh
Cisco IOS Software, C3560 Software (C3560-IPSERVICES-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 14:19 by yenanh
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SE1, RELEASE SOFTWARE (fc)
Core_PatioI uptime is 7 hours, 53 minutes
System image file is "flash:c3560-ipservices-mz.122-25.SEB4/c3560-ipservices-mz.122-25.SEB4.bin"
cisco WS-C3560G-48PS (PowerPC405) processor (revision D0) with 118784K/12280K bytes of memory.
Processor board ID FOC1024Y205
Last reset from power-on
1 Virtual Ethernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:18:73:5E:90:80
Motherboard assembly number : 73-9705-04
Power supply part number : 341-0108-03
Motherboard serial number : FOC102255HX
Power supply serial number : DCA10221EWK
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C3560G-48PS-E
System serial number : FOC1024Y205
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number : CAT10180MUU
Top Assembly Part Number : 800-26346-03
Top Assembly Revision Number : A0
Version ID : V03
CLEI Code Number : COM5D00ARA
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 52 WS-C3560G-48PS 12.2(25)SEB4 C3560-IPSERVICES-M
Configuration register is 0xF
_____________________________________________
Current configuration : 2666 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Core_PatioI
enable secret
enable password
no aaa new-model
vtp domain metro
vtp mode transparent
ip subnet-zero
no file verify auto
spanning-tree mode pvst
no spanning-tree vlan 1
vlan internal allocation policy ascending
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
description Carolina
interface GigabitEthernet0/22
description Vias_Ferreas
interface GigabitEthernet0/23
description Edif_Logistica
duplex full
speed 100
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
shutdown
interface GigabitEthernet0/46
description Conexion_Lamplex
duplex half
speed 10
interface GigabitEthernet0/47
description SDH_MARCONI_AMARILLO
duplex full
speed 100
interface GigabitEthernet0/48
description Cascada 2950
duplex full
speed 100
interface GigabitEthernet0/49
interface GigabitEthernet0/50
interface GigabitEthernet0/51
interface GigabitEthernet0/52
interface Vlan1
ip address ####.####.####.####
ip default-gateway ####.####.####.####
ip classless
ip http server
control-plane
line con 0
line vty 0 4
password
login
line vty 5 15
password
login
end
If a switch is running CMS for 2 to 3 days, and the switch is low on memory, the switch fails with an out of memory error.
The workaround is to close the browser and relaunch CMS.
Cheers,
Masood Ahmad Shah
BLOG: http://www.weblogs.com.pk/jahil/
Thanks, by your aid, According to I understand the official notice you recommend that it updates the IOS of the interrumptor?
That it is the CMS?
It can that is problem of the circuitry of the Switch?
