Low power consumption 10Gbps switch or router
astarjones20
Hi guys,
I need to setup a new little PoP in a DC which is giving me max 200W of power. In similar situations i usually put a couple of catalyst 3850 with stack config, for production traffic and a 3750 for management one. This build consumes around 295W
Do you have a suggestion on what can i put in this 5 rack unit space which consumes less than 200W? I can use MLAG instead of stackwise, what i need are at least 12 10Gbps ports on production switch and a couple of 1Gbps ports for management (routed or switched ports is not a constraint)
PSU have to be AC
Thanks in advance!
Steven L
This is not the correct forum for this question. probably should post it in the networking space.
