lsa5 forward address issue
sarahr202
Level 7
Level 7
Hi everybody.
Please consider the following example:
R2---200.200.200.0/24---s0//0--R1-s0/1--------199.199.199.0-----R3.
R2 is not running ospf. while R1 and R2 are running ospf in area 0
R1 config:
router ospf 1
log-adjacency-changes
redistribute static subnets
network 199.199.199.0 0.0.0.255 area 0
network 200.200.200.0 0.0.0.255 area 0
interface Serial0/0
ip address 200.200.200.1 255.255.255.0
interface Serial0/1
ip address 199.199.199.1 255.255.255.0
R1#show ip route
Gateway of last resort is not set
C    200.200.200.0/24 is directly connected, Serial0/0
C    199.199.199.0/24 is directly connected, Serial0/1
C    1.0.0.0/8 is directly connected, Loopback1
S    10.0.0.0/8 [1/0] via 200.200.200.2
The issue is R1 should set forward address as 200.200.200.2 in LSA5. But for some reason, R1 is not doing that.
R1 can ping 200.200.200.2
R1#ping 200.200.200.2
Sending 5, 100-byte ICMP Echos to 200.200.200.2, timeout is 2 seconds:
Thanks.
Happy Holidays!!
Below is the show running output from R1;
R1#show running-config
Building configuration...
Current configuration : 1313 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip domain name lab.local
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
archive
log config
  hidekeys
interface Loopback1
ip address 1.1.1.1 255.0.0.0
interface Serial0/0
clock rate 2000000
interface Serial0/1
clock rate 2000000
router ospf 1
ip forward-protocol nd
ip route 10.0.0.0 255.0.0.0 200.200.200.2
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
Peter Paluch
Hello Sarah,
Please check the following document:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009405a.shtml#topic1
Specifically, it states that for Cisco's OSPF implementation to set LSA-5 forwarding addresses to a non-zero value, all of the following requirements must be met:
These conditions set the forwarding address field to a non-zero address:
  • OSPF is enabled on the ASBR's next hop interface AND
  • ASBR's next hop interface is non-passive under OSPF AND
  • ASBR's next hop interface is not point-to-point AND
  • ASBR's next hop interface is not point-to-multipoint AND
  • ASBR's next hop interface address falls under the network range specified in the router ospf command.
In your case, you are using Serial interfaces, i.e. a point-to-point interface. That may be the reason that OSPF does not set the forwarding address to a non-zero value.
Best regards,
Peter
Peter Paluch
Hello Sarah,
Best regards,
Peter
Thanks Peter.
