MAB auth fail issue
ITexpert
Level 3
Level 3
I Configure mac authentication bypass with NPS server and its working if I add mac-address in active directory.  But for Unknown devices ports are still going error-disable state 9(Orange) .  instead it should go in guest vlan.
Please see my configuration and let me know if I am missing anything.
aaa new-model
aaa authentication dot1x default group radius
aaa authorization network deafult group radius
aaa  accounting dot1x default start-stop group radius   (i dont know the purpose of this command)
dot1x system-auth-control
Interface G1/0/3
switchport mode access
authentication event fail action authorize vlan 10
authentication host-mode multi-auth
authentication order mab
authentication port-control auto
mab
Thats all I configure , basically i just to want to use mac-address from NPS to allocate vlans and If it fails then switch just assign Guest Vlan.
pieterh
You can configure an authentication failed (auth fail) VLAN for each 802.1X port on a switch stack or a switch to provide limited services to clients that cannot access the guest VLAN. These clients are 802.1X-compliant and cannot access another VLAN...
This option is not intended for devices that are not DOT1x aware! and only use MAB.
in your NPS you need to configure a policy to assign the guest vlan whenMAB authentication fails.
I am unable to Figureout, how to create policy in NPS for non domain objects like if unknown device connect to my network, i will not have his mac-address and NPS will only move objects which are in Active Directory.
Any help will be appreciated ?
